Compatible wire harness
Old Feb 4, 2015
cperez53's Avatar
cperez53 is an unknown quantity at this point
I was just wondering if anyone knew for sure if every honda civic no matter the trim comes with a floor wiring harness. There is a myth that they always put them in and then just add the other accessories and their wiring harnesses depending on the trim?
Old Feb 4, 2015
Re: Floor wiring harness question
Yes, every car has a floor wiring harness.
They are not 'one size fits all'.
There are like 50 different choices depending on body style, year, trim and equipment.
Old Feb 9, 2015
cperez53's Avatar
Honda civic 6th gen. Floor wiring harness
I was just wondering whether anyone knew how to remove the floor wiring harness off of any honda civic 1996-2000 sedan or of a place with instructions? Any help would highly be appreciated
Old Feb 9, 2015
Re: Honda civic 6th gen. Floor wiring harness
Start at one area and remove everything in the way as you follow the harness around the car?
Seats and carpet usually have to come out as sections of the harness run side to side under the front seats.
Old Feb 12, 2015
cperez53's Avatar
Compatible wire harnesses
I was wondering if a 1997 honda civic lx door wiring harness is compatible with a 1999 honda civic lx floor wiring harness without having to modify them in anyway or with some modifications or not at all? And if I do have to modify them can you tell me how and what has to be modified? Thanks for any help
Old Feb 17, 2015
cperez53's Avatar
Old Feb 18, 2015
Re: Compatible wire harness
If you want a straight swap you have to get one from an identical car.
Then you will discover that used harness is just as old as your old one.....
and just as bad as your bad one.
If it's not already as bad, it will be in a short time.
Old Feb 19, 2015
cperez53's Avatar
So are they compatible with eachother since they are the same generation of civic?
Old Feb 19, 2015
I have now consolidated all the threads you started that are basically the same.
The answer is now in this thread.
Old Feb 23, 2015
cperez53's Avatar
What?
Old Feb 23, 2015
Originally Posted by cperez53
so are they compatible with eachother since they are the same generation of civic?
Originally Posted by ezone
the answer is now in this thread.
they are not 'one size fits all'.
what?
No !!
Old Feb 24, 2015
cperez53's Avatar
No !!
Ok thanks for the answer ;D
BootyDo
Jun 21, 2016 03:45 PM
Amulon
Aug 18, 2015 11:03 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
