Dash lighting problem?
Old Aug 18, 2014
Yellow_EK's Avatar
Yellow_EK is an unknown quantity at this point
Whenever I turn my headlights on at night, I have no dash lights.. It's not the bulbs, I replaced every single one to make sure.. I'm assuming a short in the wiring? Also replaced the cluster
Old Aug 18, 2014
CraigW's Avatar
Re: Dash lighting problem?
6th gen dimmers tend to fail. (electronics contained behind the dimmer ****)
Shorts blow fuses....you have an open.
You can bypass it and have full brightness cluster etc.
Old Aug 18, 2014
Yellow_EK's Avatar
so then
Old Aug 18, 2014
Yellow_EK's Avatar
So basically just take the dimmer out?
Old Aug 18, 2014
CraigW's Avatar
You will have a hole.
The 6th gen manual is readily avail online (mine is at home) and you can likely find some utube info that may have the wire colors.
You will need to bypass it for bulbs to light. Make a jumper and leave the control unit in place.
voblak2
20
May 4, 2023 02:08 PM
ywgflyer
May 15, 2015 05:05 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
