sts fail?
Old Aug 4, 2014
abzack's Avatar
abzack is an unknown quantity at this point
sts fail?
My obd2 gave me sts fail . What does this mean ?
Old Aug 4, 2014
Poopies's Avatar
Super Moderator
Re: sts fail?
What year/trim do you have? Did it give you the actual code number?
Old Aug 4, 2014
abzack's Avatar
Re: sts fail?
2000 civic ex coupe 96,000 miles been getting p1457 evap code. changed canister shut valve after testing it as alldata shows for this code and showed the canister shut valve was bad so I replaced it and no luck still have code coming up. got the sts fail when i tried to run a test with my scanner but I dont know what it means. also did a smoke test and didnt find any visible leaks.
Old Aug 4, 2014
Re: sts fail?
Seems like STS FAIL would be a message from your scanner, not the car.
As in, it is unable to run bi-directional controls test or an EVAP system self test for whatever reason.
What kind of scanner are you using, anyway?
Status fail?
Old Aug 5, 2014
abzack's Avatar
Re: sts fail?
Not The best odf scanners , but its what I've got its an Aulltel 519. ezone you are probably right when I try to run an system scan it comes back as unsupported
Old Aug 5, 2014
Re: sts fail?
status would be my guess too.
Old Aug 5, 2014
Re: sts fail?
So STS probably means something like "Self Test Status"?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
Bonobo
Oct 2, 2015 06:58 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Stock 99
Sep 5, 2015 06:06 AM
