Center Dash Lights Not Working
Old Oct 4, 2013
generye's Avatar
generye is an unknown quantity at this point
I have a 2000 Civic EX 2 Door Coupe purchased used. The lighting for the center controls (vent, heat, fan speed) does not work when the lights are turned on. It had a replacement radio. I tore the center dashboard apart and removed the radio. All 3 wire plugs were plugged in. I unplugged and re-plugged the connectors. No loose wires evident. No cut wires evident. I re-installed the radio and dash components. I checked the single fuse under the dash and the fuse under the hood. Both are good. Could there be a problem with the control unit internally? Is there another fuse for the EX 2 Door Coupe? Is see from a Honda Parts drawing that there is a bulb that is on the right side of the unit. Could it be bad? I'd like the lights to work. Help.
Old Oct 5, 2013
CraigW's Avatar
Re: Center Dash Lights Not Working
Are other dimmable bulbs working ??
Those filaments in those tiny bulbs can get knocked loose pretty easy, maybe you need bulbs replaced.
Old Oct 5, 2013
generye's Avatar
All other dimmable bulbs are working. I have a new bulb on order at the local dealership. Hopefully this will solve the problem. Thanks
voblak2
20
May 4, 2023 02:08 PM
ORskier
May 3, 2015 12:54 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
