Power Door Lock Issue
Old Oct 7, 2013
phillyphan's Avatar
phillyphan is an unknown quantity at this point
Hello, I'm new to this forum. I sold my 95 Civic EX last year and decided to purchase a 98 Civic LX for my daughter a couple of days ago. I'm trying to work out all of the bugs right now. One of them is the power door locks not working. The person I bought the vehicle from said the replaced the driver side actuator to address the problem, but that didn't fix it. I can lock and unlock the door with the key, but not the lock switch. I checked the continuity on the switch and that's fine. I checked for voltage and found voltage at all three pins. I was expecting to have 0v at the black wire since that was ground, but I had the same voltage there as I did at the other two wires. I added a picture of the wiring diagram I found online. Is it possible he hooked up the actuator wiring wrong causing voltage and ground to be swapped? Any help would be much appreciated.
Old Oct 7, 2013
Re: Power Door Lock Issue
on the switch
That's wrong.
What you expected was correct.
The black wire on the switch is a ground.
You are missing that ground.
It is probably missing the same ground from the actuator and the control unit too.
Those cars like to break the wiring in the door jamb right up at the connector on the door.
roverben
Jan 21, 2019 05:16 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
