PLZ HELP!! intake manifold
Old Dec 30, 2012
Blazz's Avatar
Blazz is an unknown quantity at this point
I got a 2000 civic ex that the old owner gave up on..
They put a 97 non vtec engine and reused the 2000 intake manifold .
there is a loud air leak coming from the top of the manifold were it meets up with the head.. when i spray carb cleaner it rev's up. not in just one spot the whole top of the manifold seems to be sucking it up..
i put a new gasket on but it did not fix and old one looked like it was ok.
its a very loud air sucking noise.
is the problem the 2000 vtec manifold on a 97 non vtec head?
Old Jan 3, 2013
Blazz's Avatar
Re: PLZ HELP!! runing ruff and backfires[video]
Intake is ok the vac lines were not installed right...
I cant get the car to run right.. it will backfire if I hit the gas, and runs ruff!!
ive checked spark/wire/cap.. cleaned injectors. I get 150psi ish in all cylinders.
this car sat for 5 months, but ran this way when it was parked.
I put new head gasket on but it did not need one. .
ive checked timing [with gun and on the pulleys]
this is a 2000 ex with a d16y7 installed.
ill see if I can post a video so you can hear my nightmare..
ok so I got the video.. its cold out and the car is running better.. it sounds like its running on 3 cylinders in the vid. its running better in this video. normally it will want to stall if I hit the gas like this..
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1364& transactionid=1357267057-7615120133&posted_by=_www.civicforums.com&youtube_ video_id=Nye-m_HH7PY[/autostream]
SammySC
121
Apr 7, 2017 07:43 PM
Solo Flow
Oct 4, 2015 07:52 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
Luluharp
Sep 27, 2015 11:56 AM
