civic 2000 sedan ac compressor / sensor
Old Jul 7, 2012
rvs's Avatar
rvs
rvs is an unknown quantity at this point
Hi,
My a/c periodically (when its hot outside), stops blowing cool air. Air does come out but its not cool . Then after 20 mins sometimes cool air resumes (and it is very cool) and so on.
Took it to a Midas. They first said we needed to recharge the a/c (was charged 140 dollars after discounts). The problem still existed. Took it back , now they are telling me some fuse/sensor on the compressor is malfunctioning. They have to replace the entire compressor since the fuse is integrated into the compressor. They willl also have to replace the filter and recharge again. So the cost will be 800 dollars (in addition to the 140 they already charged me).
Can the fuse/sensor be replaced without replacing the a/c compressor? Is it really integrated into the a/c?
Is the cost reasonable?
My car make and model=> honda civic lx 2000 (sedan)
Appreciate any advice in this regard.
Old Jul 10, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: civic 2000 sedan ac compressor / sensor
Well if you want to redneck it just wire the clutch for the AC compressor to a hobby switch in the dashboard. It sounds like the AC isn't turning on when it should so you can make it spin at will with a switch.
If you power the clutch to a cigarette lighter plug then you don't need to wire a switch. just plug it into the cigarette lighter when you want the AC.
It may ice up though, the air will be very cold probably!
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
dano2005
Apr 14, 2015 01:58 AM
