exhaust leak
Old Jan 5, 2011
cueist63's Avatar
cueist63 is an unknown quantity at this point
exhaust leak
I have a small leak in my exhaust about half way back under the car where
there seems to be a seam in the pipe. I would like to put something on it or around it temporarily to stop the noise. Would some liquid solder work or is there a clamp I could buy or make to go around the pipe. 98 civic lx is the car. thanks
Old Jan 5, 2011
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Re: exhaust leak
If it is at a flange connection cut the old bolts out replace the crush seal with OEM one and new stainless bolts from Home Depot. Don't bother with the temp stuff it stinks and doesn't work.
Old Jan 5, 2011
cueist63's Avatar
Re: exhaust leak
It's not at the flange, its about halfway down along the pipe that goes all the way back to the muffler, more like a weld seam that I understand fails quite normally.
Old Jan 5, 2011
lazlong's Avatar
Re: exhaust leak
Google "exhaust sleeve clamp". You'll need something hi-temp to fill the edges. Depending on the size of the hole the muffler shop can usually fill it pretty cheaply. Good luck.
Old Jan 5, 2011
TRIZ's Avatar
Re: exhaust leak
Or there is always exhaust tape.. kinda like duct tape, but high heat and made to easily fix exhausts.
Old Jan 6, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: exhaust leak
or u can use a tin can trick
where u buy those chef boyaredee cans
cut them so u can wrap around the exhaust pipe
then use 3 clamps
1 at each end and 1 in the middle
after that then ur golden.
my dad did this trick so he can pass inspection and it does work for a while at least to get through the season
Old Jan 6, 2011
Deleon2c's Avatar
B18C1
Deleon2c is an unknown quantity at this point
Cool Re: exhaust leak
then use 3 clamps
^---^ U Have Me DyiN Bro, Hahaha
Old Jan 6, 2011
Re: exhaust leak
i know lol
but it did work for a lil while
u know money isnt always available
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
Reverb2005
Jun 26, 2015 06:22 PM
silvervtec01
Dec 9, 2001 08:50 PM
