2000 civic DX vibrations under hood
Old Nov 11, 2010
kyle_l88's Avatar
kyle_l88 will become famous soon enoughkyle_l88 will become famous soon enough
Hey guys not sure if you can be of any help but I am just a little irritated by some vibration coming from the engine bay. Usually happens around a low RPM, not idling but around 1.5 - 2K rpms. It almost sounds like it could be the heat shield over the headers? Any ideas on this? Someone with the same issue maybe. If the engine i running at the perfect RPM it creates quite the resonant frequency of vibration lol. very annoying. Any suggestions on what might be causing vibrations under the hood ? Thanks
Old Nov 11, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Re: 2000 civic DX vibrations under hood
Well have you looked at the heat shield on the manifold? Its very common, all of mine are removed. If thats not it look at the cat there is a a heat shield there too (2 pieces.) Its probably one of those... Lastly make sure the rod that holds up your hood isnt moving. My clip broke and was making noise.
Old Nov 11, 2010
kyle_l88's Avatar
sweet thanks ill check all those and see how it goes
Old Nov 15, 2010
^^ugh......why did you quote me without quotes and then say nothing further?
Old Nov 15, 2010
kyle_l88's Avatar
haha. well i figured out what it was. While changing my oil yesterday I tapped on the exhaust pipe to hear where the rattle was coming from. Found it was a heat shield about 2/3 of the way back on top of this part that was wider than the rest of the exhaust. Not the cat, but something else? maybe a resonator or something, not sure. Anyways there was a shitty heat shield held on with an adjustable clamp. So i tightened it and what do you know its gone!.
Old Nov 15, 2010
kyle_l88's Avatar
and this mattsteel008 seems to be quoting alot of threads word for word, whats up with that ? for instance this link
https://www.civicforums.com/forums/1...eedometer.html
Old Nov 15, 2010
troll or bot... ignore it. Glad you found the issue.
usajags84
15
Aug 19, 2015 03:12 AM
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
