how do you calibrate a speedometer?
Old Nov 11, 2010
ccrred's Avatar
ccrred is an unknown quantity at this point
i replaced a gauge cluster in my 96 Civic and now it is 5+ miles per hour faster than it should be. how do i calibrate it or is it even possible?
Old Nov 11, 2010
lazlong's Avatar
Re: how do you calibrate a speedometer?
Go to the Honda house and pay them $300 or live with it. Sorry.
Old Nov 15, 2010
or try a different cluster
Old Mar 5, 2012
wvdude's Avatar
wvdude is an unknown quantity at this point
Ok, so then what do they do to it, then?
Old Mar 5, 2012
I can think of a few things to do, but there isn't much we can do with the speedo itself.
If the speedo isn't accurate, one could send it to a speedo repair shop.
For a price, of course.
Check (ask the owner) if the drive gear and trans is original,
check the speedo head for correct application
Check tire diameter for being close to original
Use a scanner to read the vehicle speed as seen by the PCM and compare it to the speedometer.
Pace it with a GPS
Figure that the error is well within 10% and it is fine.
(I forget what the actual amount of acceptable error is at the moment.)
Tell you nothing is wrong:
Operating as designed (not necessarily as desired).
Charge you a $100 bill for my time
Old Mar 5, 2012
a few mph is normal, there is always error esp in a civic cluster. if you want accurate, go buy ferrari lol. all the dealer does is diagnose and replace. no fixing these things and they usually put a sticker in the door that says mileage reset to zero on such and such date. a few may send it out to have the mileage reflashed but that costs extra and most do not even bother. just find a used one on ebay with similar miles. most speedo shops will not touch the newer 03+ clusters because they are difficult to get back together by hand (actually near impossible).
Old Mar 6, 2012
FordSlayer's Avatar
Gangsta Sexy
FordSlayer is an unknown quantity at this point
You can change the speedo drive cable/gear on the tranny, but i wouldnt mess with it.
Old Mar 6, 2012
hawkijustin's Avatar
hawkijustin is an unknown quantity at this point
Hmm so what your saying is that when your going 55 your speedo says your going 60? That seems about right give or take a few mph. I believe most if not all car makers do that because (and bash me if im wrong) its illegal to sell a car with a speedo that reads slow so they play it safe. Heck I had a 06 Kawasaki z750 and the speedo read almost 10mph off at 75 and that was normal.
Old Mar 18, 2012
azkicker0027's Avatar
azkicker0027 is an unknown quantity at this point
or maybe get a different wheel/tire setup to compensate for the speedo difference? i found out that my cousin's coupe, that he sold me, shows 5mph faster than actual by comparing it to my nav unit. i also verified it with some speed boxes that cops put out on the streets, and also by driving next to a newer civic with those digital speed displays that can be easily seen from the outside.
oh well, this should keep me away from cops.
Old Mar 18, 2012
http://www.miata.net/garage/tirecalc.html
Crazygrlinak
Oct 8, 2015 05:06 PM
260000milesgoal
Sep 25, 2015 07:41 PM
jerry38
Sep 20, 2015 08:38 AM
MamaBear2015
Sep 15, 2015 09:35 PM
Bricoleur
Sep 9, 2015 06:48 PM
