Stock Airbox new Intake
Old Aug 14, 2010
Pimpedrabit's Avatar
Pimpedrabit is an unknown quantity at this point
I have a 98 civic lx and i put an AEM short ram intake for the EX models on my stock air box. Is that bad.
Old Aug 14, 2010
02civicsi02's Avatar
Low and slow!
Re: Stock Airbox new Intake
Like what do you mean. Do you mean you took the top part of the airbox off and put the short ram on top of the open box. Do you have a picture or something.
Old Aug 14, 2010
Bad pic, but i basically just put the short ram on the air box, usually when i see this engine the have the short ram directly on the opening
Old Aug 14, 2010
https://www.civicforums.com/forums/a...pictureid=2187
Old Aug 14, 2010
Low and slow!
It will work fine but it will be better if you just take the airbox out since you really are not using it. Though there could be some cold air from the air box reaching the intake you have there. And where do you have the breather running to that is on the valve cover.
Old Aug 14, 2010
I left the breather on the air box and never reset the ecu. I wasn't sure what to do since some one gave me this short ram for free and it was the only logical way to instal it.
Old Aug 14, 2010
Low and slow!
I was talking bout the hose that goes from the valve cover to the intake pipe near the throttle body. What did you do to it, is it just running free or do you have it plugged somewhere. And no need to reset the ecu for an intake.
Old Aug 14, 2010
Oh, I'm sorry. I have done nothing to it. I am trying to make this car as efficient as possible and retain high mpg. I already have good pipings and an aero turbine muffler. What else should i do?
Old Aug 14, 2010
Low and slow!
The breather should be hooked up to the intake pipe so you might want to do that. The breather is a vacuum for part of the head. There are several vacuum lines that go to the head that which help oil go where it is suppose to. So hook it up to your intake pipe. Plus also if you dont have anything hooked up to it then it can absorb mostuire and you dont want that. Just giving you a heads up man.
And for some mods you can start saving up and buy you a real catback exhaust system then buy you a new header. The header depends on what state you are in cause of emmissions. If you are in a state that doesnt give a crap then get a race header, if they do care then get a 4-1 header with a hi flow cat.
Old Aug 15, 2010
Benny88's Avatar
Benny88 is an unknown quantity at this point
Mate u should always reset your ECU when changing engine parts..even an intake.
the brain of the car needs to no whats changed...for best performance and general running
Old Nov 3, 2010
shelasharmin's Avatar
shelasharmin is an unknown quantity at this point
Cena romántica con un toque especial.
Originales , Cenas romanticas , Romanticos.
Quieres que tu cena romántica sea romántica o no? si lo que buscas es sorprenderla, una cena llena de velas, música romántica y un buen vino pueden ser los mejores compañeros para una noche especial, piensa en algo que el de un toque especial como una caminata bajo las estrellas, un baile con su canción favorita, en fin lo que les guste, para hacer de esa velada una noche única.
http://volopapilio.com.mx/cenas-Romanticas.html
carid
Nov 7, 2015 01:46 AM
Misfit2613
Jul 30, 2015 09:49 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
