Need Help: 6.5 Speaker won't fit front door
Old May 29, 2010
aznrocbtm's Avatar
aznrocbtm is an unknown quantity at this point
Ok, so I bought a Soundstream component speaker 6.5, which is what the size is stated for a 1999 honda civic ex sedan. I took out factory speaker and tried to fit this in the slot. The diameter of the speaker is about 1/3 of inch bigger than the factory speaker, which make it not fit. The depth is not the problem, the diameter of the speaker is. Speaker expands wide that I have to cut where the speaker-cover clips on to. I haven't cut yet.
How would i go about modifying the front door speaker port so I can mount the 6.5 soundstream speaker in as well as use the speaker-cover so it looks stock?
I appreciate any help in advance!
Old May 29, 2010
Re: Need Help: 6.5 Speaker won't fit front door
Use a dremel..
Old May 29, 2010
aznrocbtm's Avatar
Thanks riceboy, could you expand on that?
Old May 29, 2010
I'll snap some pics of what I did in my '02 later to give you ideas
Old May 29, 2010
aznrocbtm's Avatar
Nice! Thx!
Old May 29, 2010
aznrocbtm's Avatar
Has anyone else had experience in installing aftermarket 6.5 speaker for 96-00honda civic "SEDAN" types in the door panel??? I appreciate any help!
Old May 29, 2010
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
I did the same thing, bought 6.5's. When I realized they wouldn't fit and keep the stock covers I ended up going with 5.25 speakers and building a custom housing for them
Old May 29, 2010
aznrocbtm's Avatar
AWW MAN! So the 5.25 fits nicely with lil mod and you can still use the speaker-cover? I wish I knew earlier, I cant return these. Does anyone want Soundstream 6.5 components for 45 plus shipping Brand NEW??? My lose your gain.
Old May 29, 2010
Mavrick272's Avatar
Speak(er)ing of that I still have my 6.5 Wolfenhags if anybody wants them, hahahaha
Old May 29, 2010
aznrocbtm's Avatar
HEY! dont jack my thread. get your own.
Old May 29, 2010
lordhelmet's Avatar
Use a spacer.
Old May 29, 2010
aznrocbtm's Avatar
Can't use a spacer. The speaker mount is directly onto the plastic panel connected to the metal door, not the metal door.
Old May 30, 2010
Sorry man.. wasn't able to snap pictures today.. I'm doing an oil/tranny fluid change tomorrow, so during the draining phase, I'll rip apart my door panel and show you how my 6.5's fit in my EM2.
Would you be able to take pictures of what you mean by your last post?
Old May 30, 2010
sheepdog's Avatar
sheepdog is an unknown quantity at this point
crazy idea that you might not like, but I plan on mounting my 7" midbass (huge magnet) by removing the map pocket/speaker pod and building a new baffle in its place. Good luck...I know I will need plenty.
Old May 30, 2010
as promised, pictures
Got a spacer kit necessary to fit deeper speakers (I'm running alpine type-r's, SPR-17C). Max allowable depth without the spacer is 1.75, I believe. The depth of these speakers are 2.5". If you look at the rust (yes, I know I need to fix that.. lol), that's where I dremeled out to fit the speaker.
The spacer fits in the clip-holes (I guess you'd call them) in the OEM locations. 2 clips on the bottom and 1 screw up top.
Get creative with it, man
Old May 31, 2010
zzSKITzz's Avatar
zzSKITzz is an unknown quantity at this point
i went the opposite direction and trim'd the back of the pod open. took a lil bit and sum patience but worked out. the holes on the speakers lined up and everything
Old Jun 1, 2010
marek91's Avatar
marek91 is an unknown quantity at this point
i put 6.5 speakers in my doors in my 2000 sedan my after market speaker had litle metal clip around on the sides making the speaker not fit so i snipped them of and fits liek a charm but only one screw one screw holds it and must be tightend about every 4 months because the bass from my subs loosens it up and makes it rattle but other then that its all good !
Old Jun 1, 2010
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
i made a mistake cutting the bottom piece of my cover
then i made another mistake by cutting the cuppling behind the speaker
where the sound reflex off and prevent water from getting into ur speaker
i went through 2 pairs of speaker already cuz of water getting in
and creating massive rust.
use wat u can, like spacers, adapters, or watever they have to make ur speaker fit.
i use the same speaker and put it in my friend sedan and it sounded way better, on top of that im using 4 channel amp
im guessing the back cuppling help push the sound out, now my back speaker sound louder than the front
Old Jun 5, 2010
aznrocbtm's Avatar
Sorry guys, was gone for a whole week. Went to Vegas.
Thanks XRiceboyX, for the pictures. Your front door speaker mount is different from my 99 civic sedan door speaker mount. Mine mounts on the door pod piece. Yours looks like it mounts on the metal frame door. I will post a picture of it asap. Its 1am now.
Marek91, i seriously thought about cutting the metal surround on my 6.5 to make it fit, but thats what is holding part of the rubber surround of the speaker together. I dont want to weaken the glued rubber to the metal.
Asianboy, you can use a baffle box insert to protect your speaker from the rain since you cut the speaker port backing. This is what it looks like: http://www.crutchfield.com/p_237XT65...h.html?tp=2809
Thanks everyone, I just bought 5.25 speakers co-axial, which isnt as good as my 6.5 component. But most important to me is to be able to upgrade my speakers and keeping the factory door panel speaker cover
Anyone need brand new 6.5 Component set from Soundstream for 45.00 plus shipping? Pickup preferred. From Anaheim, CA 92806 zip code.
Old Jun 7, 2010
thanks i saw that the other day and will be ordering it along with a new pair of speakers, glad u bought new speakers instead of tryign to cut the factory door panel cover
Old Jun 7, 2010
****, you shoulda hit me up when you were in Vegas. I coulda at least looked at it for you
MamaBear2015
May 18, 2015 07:37 PM
SSMatey
Apr 13, 2015 06:09 PM
ademarco6
Nov 16, 2001 10:19 PM
doublins
Nov 11, 2001 07:01 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
