Lacking Low End
Old May 28, 2009
Schuy's Avatar
Schuy is an unknown quantity at this point
Lacking Low End
98 ex auto
Since i had my oil changed last ive noticed a signifigant drop in power below the 3000rpm range. Its like it almost bogs till its gets up to 3k and then it takes off almost like turbo lag (but i don't have a turbo and its just normal power) I checked the oil on th dip stick and it does appear to be over filled slightly by maybe an eigth quart (dumbassses)
Could too much oil be bogging it down? or should i be looking at new plug wires and such instead? the wires appear stock but the plugs were just replaced last fall. Also im fairly certain i have a weak alternator, so could this be another issue?
Old Jun 1, 2009
sql_civic's Avatar
Re: Lacking Low End
Check your transmission fluid. Maybe your oil changing Einsteins messed with it.
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Jodster
Bolt-on Engine Performance
Jan 1, 2002 07:45 AM
Aznnp77
Dec 13, 2001 04:03 PM
Mokushi
Dec 3, 2001 08:11 PM
skywalker
Nov 8, 2001 05:04 PM
