97 Civic ECU code 5 or 41
Old May 26, 2009
gp78's Avatar
gp78 is an unknown quantity at this point
Hi Every1!
I pulled the code, I get 4 long beeps and 1 short is that 5 or 41? 5 is map sensor 41 is primary oxygen. How do I fix the primary oxygen
Thanks
Old May 26, 2009
sql_civic's Avatar
Re: 97 Civic ECU code 5 or 41
41
Replace the O2 sensor.
Old May 26, 2009
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
no it's not the O2
it's the heater in the O2 sensor. two diffrent circuits.
Old May 27, 2009
sql_civic's Avatar
Originally Posted by DieMaster
no it's not the O2
It doesn't matter. It's a 4-wire O2 sensor. The heater circuit consists of 2 of these wires and the heater is inside the sensor so you need to replace the whole sensor.
Old May 27, 2009
DieMaster's Avatar
but how do u know it's automoticly the sensor? it could be in the harness before the sensor. then u just bought a $80 sensor for nothing then a soldering iron could have fixed.
Old Jun 1, 2009
sql_civic's Avatar
Experience, kid. The heater circuit inside the sensor eventually shorts out from heating up all the time. If you want you can ohm out the sensor to be sure but 99.99999% that's what it is. The chances that the wiring harness has a short is real low unless someone's messing with it.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
tattedlariat
Apr 20, 2015 09:26 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
