Keyless Entry Problem
Old Jan 10, 2009
natey57's Avatar
natey57 is an unknown quantity at this point
i have a 96 ex coupe. i bought it with an aftermarket radio. the keyless entry doesn't work, b/c i'm 99% sure that the signal is transmitted into the OEM radio. So, im just wondering how every gets around this when they add a new stero. Thanks
Old Jan 12, 2009
matthufham's Avatar
matthufham is an unknown quantity at this point
Re: Keyless Entry Problem
more than likely a radio harness plug that's less than 20 dollars can be put in there.
but someone may have cut the old one out so a junkyard could yield a new one, but wherever you buy your plug for the aftermarket radio, the opposite plug may be available. does this make sense, it's late here
the factory radio plug that went to the back of the stock radio was probably cut off, and the new radio got wired straight to the old honda harness. a few wires like the keyless entry wires not needed for the radio to work were probably left alone, and sense havent worked. radio plugs are sold so you don't have to cut your stock honda harness and you can plug in a new plug and wire the new plug to the radio and make everything still work.
it's more crucial on new cars where there isn't an accessory "ignition" wire, instead a serial data bus wire controls that function, turning the radio on. many wires contain 2 or more functions, very complex, so a plug would be necessary there for sure.
Old Jan 12, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
To answer your question, yes the keyless does utilize the radio for operation in the 96's. Your best bet is to get an aftermarket alarm and then you can easily use the factory wiring for the keyless.
Hope that helps.
Youshoe
May 22, 2015 09:36 PM
davidarenberg
May 16, 2015 08:45 AM
Shabba
May 13, 2015 10:55 PM
darwin-t
Apr 18, 2015 09:29 PM
melga
Jan 1, 2002 05:17 PM
