Winter hates me!!
Old Nov 28, 2008
DX5spd's Avatar
DX5spd is an unknown quantity at this point
Exclamation Winter hates me!!
So the other day i was driving to my girls house I noticed my temp gauge was rising slowly but not to the piont to worry much. Then next thing I know its almost pegged and i see steam coming from under the hood at a red light. Pull over and I got NO coolant. Now i saw the back of my engine block is soaked with coolant under the IM and this is were it is leaking. First i thought head gasket but it doesnt leak from there. Its down further around were the oil filter is, I cant see anything else it could be leaking from. Then i thought is it a freeze plug or is there something else that could be leaking. I saw a big bolt looked like a drain plug or something. Im losing like a gallon every two/three days. Can anyone help. Thanks
Old Dec 2, 2008
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
Re: Winter hates me!!
are you blowing any smoke out the exhaust? Not joking does your exhaust smell sweet?? and i think there is a coolant bypass pipe on the back of the block that runs from the water pump to the thermostat. they have been known to leak from time to time. you really have to get under it and take a good look. with the car cold fill it up and pressure test the cooling system. if its leaking like you are saying then you should be able to find the leak.. Let me know your findings.
Old Dec 2, 2008
DX5spd's Avatar
No smoke and it actually stinks, but sounds sweet. I actually was thinking the same about that bypass pipe so I fired her up then looked carefully and found it. I was so glad it wasn't a freeze plug or a cracked head or something. There is a hose that goes from The IAC i think to the pipe that seems to be dripping very rapidly only when idling though. Going to check the shed for a extra bypass pipe from my old blown motor and ill get some new hose tomorrow and fix her. Gotta do something soon i drive 40 sometimes 65 miles a-day. Thanks for helping out
UltraHDGames
Jun 8, 2016 05:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Tedverseti
Sep 29, 2015 05:41 PM
Shadowbandit
Wheels and Tires
Sep 16, 2015 09:34 PM
JJ291
Sep 2, 2015 11:49 PM
