Help. The bottom Fuel Filter nut would not loosen
Old Nov 17, 2008
diamente's Avatar
diamente is an unknown quantity at this point
I followed the directions here from this website to replace fuel filter:
http://www.ehow.com/how_2245148_repl...nda-civic.html
but when i tried to unbolt the bottom nut, it wouldn't budge. I couldn't even find out what size of wrench to use. The 14mm is too small but 15 is too big. I even sprayed the PB Blaster http://autorepair.about.com/od/tools/fr/PB-REVIEW.htm but to no avail. I made sure I turned the nut clockwise because it's on the bottom. What should I do to get it loosen?
I might have striped the nut a little, if so how do I replace it?
Old Nov 17, 2008
TRIZ's Avatar
Re: Help. The bottom Fuel Filter nut would not loosen
"The 14mm is too small but 15 is too big" - adjustable wrench?
Old Nov 17, 2008
diamente's Avatar
tried that, didn't work.
Old Nov 18, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
It's a 14 mil at the filter dude. I've replaced them many times. Are you using 2 wrenches (one on each "nut") and squeezing them together?
Old Nov 18, 2008
greeen01civic4d's Avatar
if a 14 is too small, and 15 is too big, a 9/16 is inbetween.... should be a 14 and a 19
Old Nov 18, 2008
diamente's Avatar
Two wrenches on the bottom? no. someone please put up a youtube video or something. thanks.
Old Nov 19, 2008
Don't you see the hex area below the hex area on the filter? In other words there are 2 places to put wrenches. One is 14 mil, and the other is 12 from what I recall. You put the wrenches on so one is pointing 5-10 degrees past the other one. Then you put your hands over both and sqeeze them towards each other. It's the hex nut on the actual metal fuel pipe that screws out and the hex on the filter is there for support. If you're looking at it from top-down, the hex nut will loosen clockwise.
Old Nov 19, 2008
Wait a second he's right. The filter side is 19 and the pipe side is 14.
Old Nov 26, 2008
iceminion's Avatar
iceminion is an unknown quantity at this point
a large monkey wrench usually works, because it gets tighter as you turn it, an adjustable wrench does not and can result in a rounded off bolt
Old Dec 12, 2008
diamente's Avatar
Thanks. just for clarification, are you saying looking top down, the nut on the fuel filter is turned clockwise? or is it the nut on the fuel line that's turned clockwise?
I actually went to a Honda dealer. The guy said looking top down, the nut on the fuel filter is turned clockwise. But if this is the case, then it is different from what this board is saying.
mistermenphis22
Apr 3, 2016 08:06 AM
dpru
May 26, 2015 07:01 PM
Shakzhussain
May 17, 2015 12:03 PM
Ninetyatecivic
May 9, 2015 07:48 PM
superstanko
Apr 28, 2015 04:38 AM
