Having Fuse problems
Old May 21, 2008
Spankythehatch's Avatar
Spankythehatch is an unknown quantity at this point
I got a 97 hatch that i purchased a while back and i was installing a new radio and the next thing i know when i was gonna turn on my headlights the dash lights didnt come on, the icon still come on like the seat belt but the dash lights wont come on so when i drive at night i cant see my speed and such, i changed the fuse to what i thought in the panel diagram but i dont think that worked. got any ideas what i could do to fix my problem any help is greatly appreciated
Old May 21, 2008
TRIZ's Avatar
Re: Having Fuse problems
Your bulb probably blew. Or maybe you disconnected a ground on accident?
Old May 21, 2008
CraigW's Avatar
Check the tail/marker lamps operation.
Check for open fuses in the under-hood box and/or under-dash box.
If a fuse is blown check the connections made to the illumination circuit of the newly installed radio.
Old Jun 14, 2008
sql_civic's Avatar
The fuse for the dash lights are under the steering wheel. There are several lights in the dashboard so it's probably not a blown bulb cause they all would have to have blown. You may have removed a fuse and put it back in the wrong slot. Or the wiring harness is not fully seated in the back of the gauge cluster. Or your headlight switch is busted.
Old Jun 14, 2008
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
when you installed the radio you more then likely tapped into a wire that you thought read ground on ACC for either the main power or remote from the unit, but instead it may have been an +12VDC antenae wire or something you accidently wired into.
Try wiring the power source eleswhere and make sure you just ground the headunit right into the chassis.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
roverben
Jan 21, 2019 05:16 PM
beveragemp
May 25, 2015 07:11 PM
steveneddy
May 19, 2015 02:39 PM
