Mini-Me swap ?'s
Old Feb 16, 2008
DX5spd's Avatar
DX5spd is an unknown quantity at this point
Mini-Me swap ?'s
Ok heres the break down on whats going on. I have a 1996 civic HB. D16y7 block with a d16y8 vtec head and intake manifold. Now first off will using a vtec controller instead of swapping out ecu's work ok? Do I have to wire up a knock sensor? My friend keeps telling me that I have to add an extra oil line to the head as in drilling and tapping a hole in the head and running a line from the oil pan or something like that for the vtec to work right. I dont see why I would have too but I could be wrong. I know vtec uses oil pressure to engage the lifters but what would the extra oil line do?
Old Feb 16, 2008
greeen01civic4d's Avatar
Re: Mini-Me swap ?'s
ull find more info on this gen civic on d-series.org, while this is a civic forum, d series is more technically oriented, and ull find more answers there
Old Feb 17, 2008
DX5spd's Avatar
awsome thanks man
Old Feb 17, 2008
u got it bro, im a member there, so use me as ur referral
Old Feb 22, 2008
sql_civic's Avatar
OK, I did this exact mod about 2 years ago on my car so I can help you.
Yes you can use a VTEC controller but I recommend swapping out the ECU for the P2P ECU. It has the air/fuel maps that will add power when VTEC kicks in.
Did you upgrade your injectors to the EX injectors?
You will need to wire up the knock sensor only if you install the P2P ECU.
You do not need to add extra oil lines etc - that's BS. The oil flow required to engage VTEC is in the head and VTEC solenoid.
Old Mar 4, 2008
DX5spd's Avatar
ok thanks for the info this really helps me out. Im in the process of rebuilding the motor now so ill go find the P2P ecu and a knock sensor the vtec head had the y8 int. mani on it so im sure its got the ex injectors right. Im getting new ones soon anyway. Any one got some good but cheap suggestions for good internals for my motor i got another post up with links on these deals this guy is selling
Old Mar 5, 2008
sql_civic's Avatar
I'm not sure what internals you think you need. The stock internals are good for over 200HP. A mini-me is good for maybe 126HP. So unless you plan on going FI, all you might need is a straight re-build.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
