Suspension Noise
Old Nov 6, 2007
mdawg's Avatar
mdawg is on a distinguished road
Suspension Noise
Hey any time I hit a bump or pull out off a hill that at a weird angle my tires make a very distinct crunching/squeakish type noise. If I rock my car back and forth when its in my driveway it will make this noise and its coming mainly from my back tires. I am assuming my shocks are going bad?
Old Nov 7, 2007
sql_civic's Avatar
Re: Suspension Noise
Could be the shocks but usually the squeaks come from bushings. Lay down near the sound and have someone else shake the car to zero in on the source.
Old Nov 7, 2007
mdawg's Avatar
Alright ill check it out tomorrow. Should this be a cheap fix if that is the problem?
Old Nov 8, 2007
pedigree's Avatar
pedigree can only hope to improve
i have a similar problem my car makes something like a squealing/ticking noise thats barely audible but i notice it. i get it when i overshift for a few seconds. normal?
Old Nov 11, 2007
sql_civic's Avatar
It depends on which bushing it is. Bushings are generally cheap but the replacement can be time consuming for some of them and therefore expensive.
My wife's CRV just started squeaking when you first run the car. It turned out to be the catalytic converter. There's a couple of springs where the flanges mate up with the down pipe. I don't have them on my DX but they might exist on an EX Civic to that could also be a potential source for the squeak.
EdGasket
40
Nov 27, 2015 11:11 AM
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
17
Jul 23, 2015 11:48 PM
mokkush
Jul 14, 2015 04:05 PM
