Speedo Not Working: Any Ideas
Old May 17, 2007
Thornedleaf's Avatar
Thornedleaf is an unknown quantity at this point
I have a 2001 EX and I am asking this question for my friend who has a 2000 EX. Does anyone know any solutions to fixing a malfunctioning speedometer. Sometimes it works and sometimes it doesn't. This ever happened to anyone before?
Old May 24, 2007
sql_civic's Avatar
Re: Speedo Not Working: Any Ideas
Could be a bad connection at the VSS or the VSS is going bad. Also the the wire harness plug for the speedo could be loose on the back of the cluster. Finally, you can get erratic speedo if there's a ground problem. Check the neg battery cable and the ground wire onthe thermostat housing.
Old Jun 11, 2007
CAPT CAVEMAN's Avatar
CAPT CAVEMAN is an unknown quantity at this point
I had this happen last summer to my 98. After replacing the speed sensor, and the instrument cluster, I ended up taking it to the dealer.
The mechanic told me he could guess right away what it was. Where the wire harness goes through the fire wall, it had rubbed through the insulation, on one of the wires. They did the diagnostics, and repaired it.
It was in the $90 dollar range.
But that is something to look into. He said it wasn't that uncommon, as he had done this repair a few times.
Old Jun 12, 2007
Thanks guy. I am going to do these fixes this weekend.
Old Jul 16, 2007
TRIZ's Avatar
so was it the firewall wire that was the problem, or the speed sensor?
trellex
Electrical
Jul 9, 2015 12:01 PM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
robbie374
Jul 7, 2015 02:56 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
