2003 civic ex not reving pass 4k rpm
Old Aug 20, 2018
Bullypit's Avatar
Bullypit is an unknown quantity at this point
Good morning,
I'm haven't a little problem with my car. The car isn't reeving pass 4k rpm. I recently replace the vtech solenoid, Solenoid Assy., Linear, Solenoid Assy., Shift, Sensor Assy., Map and i think it's now in limp mode is what I've seen people say on youtube and if so, how do I get out of limp mode? Any advice is much appreciated. Thank you.
Old Aug 20, 2018
Re: 2003 civic ex not reving pass 4k rpm
check oil levels first
Old Aug 20, 2018
Bullypit's Avatar
Ok. I'll do that now. Oil level looks good. Transmission oil also looks good. And it's still acting up the same.
Old Aug 20, 2018
Colin42's Avatar
check engine light?
if it isnt on you should still scan it, someone may have tampered with it so that it wont light up any more
Old Aug 20, 2018
Bullypit's Avatar
Maybe that's why I haven't gotten a check engine light. I'll scan it later and keep you posted. Thx again.
Old Aug 20, 2018
and trace back what was done - some loose wires? could be several things
Old Aug 20, 2018
Bullypit's Avatar
Thank you. I'll do that too.
Old Aug 20, 2018
I bet all those weren't cheap.
I also bet none of them were really needed.
Old Aug 20, 2018
Bullypit's Avatar
That's what the check engine light said it was so I went on fixing it. Idk.
Old Aug 20, 2018
Bullypit's Avatar
Code P1259? Vtech solenoid malfunction but its brand new??
Old Aug 20, 2018
I see that code quite often. The vtec solenoid is RARELY at fault.
Got FF data to post?
Old Aug 20, 2018
Bullypit's Avatar
I found the cause of the limp mode. There's a exact single plug that was plugged under neither the intake manifold that I swapped with the vtec solenoid and now my vtec hits hard. Lol... thanks guys. You guys are the best!!!
Nakinto
21
Jan 23, 2021 06:48 PM
Kiddta
Sep 28, 2016 01:03 PM
circuitt
18
Mar 28, 2012 06:10 PM
xxslayerodxx
17
Jan 21, 2011 03:38 PM
civicbaby
Buy, Sell, & Trade - Archive
Jul 8, 2010 06:00 PM
