2001 civic ex 2dr passenger window issue
Old Jun 25, 2018
Harryhood's Avatar
Harryhood is an unknown quantity at this point
Hi, I just signed up because I'm out of ideas what to try next on my passenger window. I've looked around on several civic forums and tried various things to fix the issue and now I'm going to lay out the issue to you folks and what I've tried.
Issue:
2 door coupe, passenger window will go down with passenger switch but will not go up. Drivers side master switch will not roll passenger window down or up. Only passenger switch will roll window down but not back up.
Troubleshooting so far:
Checked fuses - all good
Bought a new regulator and motor and, I plugged it into the connector on passenger side. Issue persists. The passenger switch will move the regulator down but not up. Master switch does nothing.
Bought a new master switch for drivers side. Issue is still the same. I tried the master switch on the old regulator and motor as well as the new one. No response from either regulator and motor using new master switch.
Rechecked fuses. All good.
Not sure where to go from here. I'm willing to try anything. Its summer now and its be nice to have all of the windows open.
Old Jun 25, 2018
Re: 2001 civic ex 2dr passenger window issue
Look for broken wire(s) in door jamb, either door or both doors.
wiring diagram and volt/ohm meter?
Croixboy
Sep 16, 2017 10:24 PM
keithkvh
Aug 4, 2016 07:30 PM
Weekendmechanic
Nov 5, 2013 11:16 AM
jack123
22
Jan 10, 2012 10:10 AM
stevelaw18
Jan 3, 2011 02:41 PM
