Overheating Issues
Old May 14, 2016
emSLOW's Avatar
emSLOW is an unknown quantity at this point
Overheating Issues
my civic overheats unless the heater is on full blast, I have replaced a couple of things but the issue still stands.
Got a new rad a month ago ( Aftermarket)
replaced the thermostat
replaced the temp sensor for fan, on the thermostat housing.
fan works mechanically, i have tried completing the circuit and it turns on.
Both hoses are hot, so coolant is circulating.
The temp needle rises up and goes down quickly.
Appreciate any help!! thank you
Old May 14, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Overheating Issues
Make sure the fans are working when they are supposed to; take her for a hard rip then pull over and check that they are on (I know you tested them with voltage, but a live check is better).
If no fluid is shooting into the overflow then hopefully the head gasket is ok.
Also check the water pump.
Old May 15, 2016
Does this mean you ran the fan direct from the battery, or does this mean you jumped the thermoswitch connector to make the fans run?
While the radiator was out did you check the condenser fins to make sure the airflow through it is not obstructed by dirt, bugs, sand, garbage?
Old May 15, 2016
emSLOW's Avatar
I jumped the connector.
Also, I will check the condenser. I remember it being dirty, what could that have to do with it though?
Thank you for the idea!
Old May 15, 2016
emSLOW's Avatar
I will do that tonight, thanks man!
What do you mean by fluid shooting?
Old May 15, 2016
If airflow is blocked, the radiator won't get cooled.
Old May 16, 2016
emSLOW's Avatar
okay thank you
Old May 16, 2016
emSLOW's Avatar
I took it for a rip, and no luck with the fans.
Old May 16, 2016
emSLOW's Avatar
Still loss at why my fans wont turn on. Have any ideas?
Old May 16, 2016
Late 6th gens and early 7th gens had a run of flaky fan temp switches, have you replaced it yet?
All air needs to be burped from the cooling system if there is any, radiator and system full to the top with coolant (but not the reservoir, its max is only partway up, not completely full)
I'd use a scanner to watch the coolant temp reading seen by the engine computer (PCM).....verify that reading against a thermometer or infrared to check accuracy.
The temp of the water EXITING the radiator through the bottom hose has to be hot enough to turn on the fan temp switch, approx 203*F (which will probably not be the same temp reading as the computer is using)
Old May 16, 2016
emSLOW's Avatar
I have replaced the sensor on the thermostat housing. Although I did not go OEM.
Okay thank you
Old May 17, 2016
emSLOW's Avatar
turned out to be a gasket. thanks for the help
Old May 18, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
What gasket failed?
Old May 18, 2016
Originally Posted by NDNV
What gasket failed?
Head gasket! (of course)
OP never did mention the coolant level being low in the radiator though....Now that he's said "gasket", I'm sure it had to be low to cause the overheating.
Old May 19, 2016
emSLOW's Avatar
Yup, it was low. No leaks on the ground so must be head gasket.
05Ep3k20si
Electrical
Nov 6, 2015 04:26 PM
crashintoty
Nov 5, 2015 08:18 PM
Kiotzu
Electrical
Oct 29, 2015 08:56 PM
joe
Jan 4, 2002 12:48 PM
artychris
Dec 7, 2001 02:01 PM
