01 honda civic blower motor not working! please help
Old Mar 22, 2014
capebreton123's Avatar
capebreton123 is an unknown quantity at this point
hi i have a 01 honda civic and the blower motor recently all of a sudden stopped working on me, it does not work at all with the switch but when i jump the motor directly to a battery it works, i took the transistor out and did some tests i found on the internet and i did them all and it tests good, also i check the fuses, any one have un idea of what could be wrong or what tests i should do? thanks!!
Old Mar 23, 2014
Re: 01 honda civic blower motor not working! please help
99% of the time the blower power transistor is faulty.
You can take it out and apart and measure the thermal fuse inside it. If the fuse is open circuit, it's bad.
Measure the blower motor amperage draw, excess amps can blow it.
Replace the pair of cabin filters too, poor airflow makes the transistor overheat..
Or sometimes they just go because it's time to go.
Old Mar 23, 2014
Hi Thanks for the replay I tested that transistor and it's the circuit is not open so it's fine any other ideas what about the acurall switch it self?
Old Mar 23, 2014
Disconnect the power transistor.
Turn the ignition on.
Jumper the 2 fat wires in the connector (blue/black to black), the blower fan should run. Does it?
Old Mar 23, 2014
Just tried jumping those 2 wires and it does not run
Old Mar 23, 2014
With the key ON: Is there B+ at the fan connector? (blue/white wire)
Old Mar 23, 2014
The fan works on full blast if I hook up a jumper dirictly to the motor
Old Mar 23, 2014
The motor is missing either power or ground.
Figure out which and get back to me.
Old Mar 23, 2014
If I put a positive on the blue/ wire it works perfect even on defferrnt speeds with the dial! Thanks a lot that realy helped now I'll just run a wire from the stereo or something and I'll be set to go!
Old Mar 23, 2014
NO NO NO!!!!
Don't be the idiot that burns his car to the ground.
Do it right
Old Mar 23, 2014
Dash fusebox, fuse 14, 10 amps
Engine compartment fusebox has the
relay for the blower
and fuse #12, 40 amps (square fuse).
Old Mar 23, 2014
Blower relay is position F
Fuse 12 is # 12
Old Mar 23, 2014
Ok thanks I will check those fuses
Old Mar 24, 2014
CraigW's Avatar
Grasp the blower relay case while someone else repeatedly turns fan switch on/off and you should feel an bump in relay when doing so.
Old May 12, 2014
drmKLRZ's Avatar
04CivicEX2drCpeAutomagik
drmKLRZ is an unknown quantity at this point
Was it this test that you did with the blower transistor?
CarStuff
Dec 6, 2020 12:52 PM
alexkharden
Apr 23, 2015 07:13 PM
vtechcivic
Apr 21, 2015 06:58 PM
paulnguyen
Apr 20, 2015 01:33 PM
jessicakaybby
Apr 20, 2015 12:11 PM
