Suspension popping Issues
Old Jul 16, 2013
  #31
GolNat's Avatar
Prelude Owner
Re: Suspension popping Issues
Ill take a look at my 01 struts I have in the basement. They are still assembled with Sportlines.
Old Jul 17, 2013
  #32
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Thanks, would it be possible for you to post a couple pics just so I can compare?
I have a feeling that ezone's suggestion could be the problem-with the spring hats hitting the body. I don't see what else there is left that could cause this since I didn't have any noises before I changed suspension so I wouldn't think other components would suddenly show that they're bad. I didn't get outside yesterday (crazy hot) but maybe tonight I can get out there and have someone turn the wheel while I stick something between the top hat and the strut tower to see if it hits.
Old Jul 17, 2013
  #33
got2run5's Avatar
Alright, so I took a look when I got home from work today and it seems like the drivers side strut stopped making noise after putting in the new mounts. However, the passenger side was making enough noise to make up for it. I found with the passenger side if I pulled on the spring hard, I could make it creak and move around a little bit. I tried the same thing on the drivers side and I couldn't budge it. Does this mean the spring isn't seated correctly in the upper perch?
Old Jul 17, 2013
  #34
GolNat's Avatar
Prelude Owner
If the spring does not have a lot of tension though you could move it so idk. I got some pics I will post in a bit.
Old Jul 17, 2013
  #35
GolNat's Avatar
Prelude Owner
Here are some pics. Let me know if you need more or have a question:
Old Jul 18, 2013
  #36
got2run5's Avatar
Thanks for the pics-everything looks like mine :/ I had a friend tug on the spring while I was sitting in the car and it was the exact same noise I hear while I'm driving so I'm pretty sure it's the culprit. The spring doesn't spin, it actually pops laterally out of position, or outwards and inwards. After popping it a few times with the wheel straight, it will no longer be movable but if the wheels are turned it is easier to pop it and doesn't get "set" in its spot.
What I don't know--whether the spring is moving in the bottom perch, top perch, or if the perch is moving around on the bearing. I don't have time to look at it tonight but I should be able to spend a little bit of time on Friday if it doesn't rain constantly.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
HiImBrandon
Jun 1, 2015 07:34 AM
reqy
Jun 1, 2015 07:05 AM
cloudguy
Apr 28, 2015 05:02 AM
