Right brake light out
Old Dec 20, 2012
lawrencem2's Avatar
lawrencem2 is an unknown quantity at this point
My right brake lights don't work. I have these
as my tail lights. However, both the left and rights work when the headlights are on. Still when the brake is pressed, the right side does not get brighter. I eliminated it being an LED problem by inserting a normal incandescent bulb in the socket. I eliminated it from being a socket problem by switching the left and rights. I checked the fuse under the hood and it looks fine. Any ideas?
Old Dec 20, 2012
GolNat's Avatar
Prelude Owner
Re: Right brake light out
So you plugged in a standard duel filament bulb and when you pressed the brake pedal it didn't get brighter?
Old Dec 20, 2012
lawrencem2's Avatar
That's correct
Old Dec 21, 2012
CraigW's Avatar
There will be a junction point where left and right (and maybe 3rd) split off... you have an open circuit from that point to the problem side. (you stated left brake light works correctly)
Own a meter, or 12 volt test light ?? Start at socket and work backwards.
Old Dec 21, 2012
lawrencem2's Avatar
I will try and do that. Is it safe to eliminate the brake light switch since my left and 3rd brake light work?
Old Dec 22, 2012
CraigW's Avatar
Switch is working.
Open circuit after junction point.
Old Dec 24, 2012
Therdest's Avatar
Therdest is an unknown quantity at this point
Originally Posted by lawrencem2
I will try and do that. Is it safe to eliminate the brake led bulbs switch since my left and 3rd brake light work?
You need to take expert guidance otherwise it could get horribly wrong.
Poopies
Apr 20, 2017 11:36 PM
MamaBear2015
May 27, 2015 12:04 PM
trellex
May 24, 2015 04:39 PM
Ma213802
May 18, 2015 07:01 AM
McD
Apr 29, 2015 03:50 PM
