Exhaust Manifold Crack? Easy Repair!
Old Jun 2, 2012
scooty's Avatar
scooty is on a distinguished road
The exhaust manifold on an LX is not cast iron as is popular belief over here! It is steel which means it should be easy to MIG weld.
I took my manifold off to have it welded and the guy told me it's not cast iron. The manifold and converter are actually made of 2 pieces of steel welded together in 2 halves. If you look carefully you can see the weld seems along the edges. The tubes are welded very cheaply to a steel flange that bolts to the engine.
Cast iron manifolds are made by pouring liquid pig iron into a mold. The steel halves used for our cars' manifolds are most likely sheet metal pressed into a die.
My manifold cracked all along one of the welds joining the #1 tube to the mounting flange. The guy showed me how the welds were done very cheaply with a machine so they end up looking like paste smeared along the joint. A proper quality weld should look like a row of overlapping circles.
So if your manifold is welded no need to buy an expensive new piece. Just have it welded. It's steel!
Old Jun 7, 2012
04 Honda Civic's Avatar
Re: Exhaust Manifold Crack? Easy Repair!
Where did you read that it was cast iron?
Regardless of the materical they are not even casted.
Old Jun 7, 2012
scooty's Avatar
I read it on a several different threads on here, for example:
https://www.civicforums.com/forums/3...m-options.html [POST #4]
https://www.civicforums.com/forums/3...-question.html [Post #1]
It's crazy the amount of misinformation you can sometimes get. I almost bought a whole new OEM manifold because I was under the impression the manifold is cast iron and cannot be welded properly.
Old Jun 7, 2012
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
from what i read, on hondatech i believe, welding a crack doesnt hold up and your better off getting another manifold or aftermerket header.
Old Jun 8, 2012
Yea, welding still is no guarantee either. I mean its a cheap fix, but certainly not a permenant one. At least in my opinion.
Old Jun 9, 2012
scooty's Avatar
Why not? The factory welds the tubes to the mounting flange after all, and in a very cheap manner I might add as this is where my manifold cracked. It was cracked almost all the way around one of the tubes where it joins the mounting flange.
They guy did a good job of welding it. The joint itself should be stronger than the surrounding metal. Now if it cracks again at the other factory welds or some where else I wouldn't be too surprised. But the weld itself is a solid repair.
So far so good, time will tell I guess, but my point is not to automatically dismiss a cracked manifold as junk and attempt to have it repaired professionally.
D17A7
Jul 6, 2015 06:04 AM
Reverb2005
Jun 26, 2015 06:22 PM
Supramk3
May 11, 2015 07:55 PM
Civic4ever1996
Apr 16, 2015 08:30 PM
AEMcivic
Dec 5, 2001 04:02 PM
