How Often Do You Do Wheel Alignment?????
Old May 21, 2012
CivicGuy2018's Avatar
CivicGuy2018 is an unknown quantity at this point
How often do you do wheel alignment on your car? Every 25,000 miles? Every 50,000 miles?
What about balance?
Old May 21, 2012
GolNat's Avatar
Prelude Owner
Re: How Often Do You Do Wheel Alignment?????
Whenever I buy new tires, or it starts to pull or not drive straight.
Old May 21, 2012
Every time you get new tires? That could be every 60,000 miles or more.
Old May 21, 2012
GolNat's Avatar
Prelude Owner
Yea! Cars can be exspensive to maintain.
Old May 21, 2012
Alignment every 60,000 miles is not much at all.
Old May 21, 2012
odncr's Avatar
odncr is an unknown quantity at this point
Whenever I notice the steering wheel isnt centered. Also I check the tires when I rotate them every 5k miles. Gives you a better idea of your needs.
Old May 21, 2012
once a year or when i change structural parts of suspension
Old May 21, 2012
sl33pyriceboi's Avatar
i do an alignment every 5,000 miles (when i change my oil) and get a printed spec sheet of what my alignment is currently like.
one of the perks of having lifetime alignment.
Old May 23, 2012
04 Honda Civic's Avatar
Its really only necessary if you change certain suspension components (tie rods) or the steering wheel is off center.
You dont really need an alignment for any other reason.
Every 5,000 miles? Someone has OCD.
Old May 23, 2012
MindBomber's Avatar
Live for the Twisties
If I had lifetime alignments, I'd go every Saturday.
Old May 23, 2012
Originally Posted by 04 Honda Civic
Its really only necessary if you change certain suspension components (tie rods) or the wheel is off center.
well, its more of a "check" the alignment (because i can; because i haz lifetime).
and if the alignment is off, they correct it.
sometimes i will lift my car and let them zero out my camber...and then drop it exactly X" to obtain a -x degree of camber. go back the next day and have then "check ONLY" my alignment and print out the spec sheet.
i run -2 in front and -1* in rear. a full gas tank+a few goodies in the trunk will make it close to -2.
lol its more time consuming than id like it to be. i avg spend 2hrs there...but thats good since i konw they are doing it right.
Old May 31, 2012
maxtierney's Avatar
EM2ti
Used to do an alignment every six months. I was also swapping every six months too, haha. Now it's every tire or component change, cause the only well alignment rack @ Express Tire closed (I had lifetime alignment with them). Everything else is on a ramp and I can get on without scraping. Since I have to pay now, it's not as frequent.
Old Jun 1, 2012
i do mine once a year or 10k miles. the specs are usually different enough to matter and make it worth doing. even a pothole can cause alignment to be thrown off. and if you hit a curb, get it looked at asap.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
BryanM.
Aug 29, 2015 03:26 PM
jedi
Aug 3, 2015 04:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
