Question About SRS Light
Old May 3, 2012
bob2002's Avatar
bob2002 is an unknown quantity at this point
First post here.
I have a 2002 Civic LX 1.7L
Recently my SRS light came on.
I went to my garage and they read the code and it is the seat belt sensor.
Needless to say my mechanic has to order the part and it will be a while until it gets fixed.
However someone told me that when the SRS light comes on it disables the whole system and now the air bags won't work either.
Is this true?
Thanks for any input and advice.
Old May 3, 2012
Re: Question About SRS Light
Is this true?
False.
Old May 3, 2012
bob2002's Avatar
Originally Posted by ezone
False.
Thanks for the fast answer ezone.
I didn't think it did but you never know.
Old May 3, 2012
It will still try to deploy bags and tensioners as needed, if possible. It may fire at maximum because it has no idea if you are buckled in or not.
Run it into a tree at 50MPH and check it out.
HTH
Old May 3, 2012
bob2002's Avatar
HTH
Thanks for the follow up ezone.
Makes sense.
I was unaware that the air bag could fire at more then one level of deployment.
What are the tensioners?
Old May 3, 2012
Charges in the seat belts, if equipped.
They would try to tighten the belt when fired.
Pulls you back into the seat by a couple inches.
HTH
Old May 3, 2012
bob2002's Avatar
HTH
Something else I have never heard of either.
Going to look it up.
However I was reading about air bags and I could find nothing on what you said about the air bag deploying at different levels.
Everything I read says the air bag can only fire at single very, very fast speed.
Old May 3, 2012
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
there are airbags with 2 stages.. if your traveling under a certain speed on the one stage will fire. faster then that set speed then both go off
Old May 3, 2012
Yes.
Dual stage airbags.
Since early 2000s.
And the seat belt plays a part in the computers decision making process, in addition to speeds involved.
Old May 3, 2012
bob2002's Avatar
Found something about deployment speed related to the sensor.
"CTS Belt Tension Sensors work in conjunction with vehicle passenger safety systems. Using strain-gauge technology, these sensors measure and relay the tension of the front passenger safety belt to the airbag deployment system— ensuring airbag deployment is proportional to the size and weight of the occupant."
My bad.
Old May 3, 2012
My bad.
Got a link?
Those cars don't use that tech in the seat belts.
All they can sense is if the front belts are buckled or not.
Old May 4, 2012
bob2002's Avatar
Got a link?
Here is the link:
http://www.ctscorp.com/automotive/se...ionsensors.htm
When you say those cars, you mean 2002 civic lx?
Old May 4, 2012
Here is the link:
Ok those items/technology in the link are not used in your generation of Civic.... And yes, I meant your car.
I have not seen them used in any Hondas (yet).
Old May 4, 2012
bob2002's Avatar
Ok, so now I am totally confused.....
I am in the eastern time zone so it's way past my bed time.
SRS light is on, code is showing the seat belt sensor.
Do I replace or ignore?
I am getting a mixed message.
If it has nothing to do with the deployment of the air bag I will ignore.
If it has something to do with the deployment of the air bag I will fix.
Which is it?
Thanks again for your valuable input.
Old May 4, 2012
You changed the subject. Not me.
It isn't getting earlier here either.
It is extremely common.
Up to you.
Not from me
Which is it?
Think about this: Do warning lights come on for absolutely no damned reason?
Yes, it is there for a reason.
Yes, it is needed for proper airbag operation.
No, this particular fault won't keep the bags from deploying. They just can't operate as designed.
And if you leave that idiot light on---how will you know if there is ever a more serious problem that causes the bags to be disabled?
Here is another valuable clue:
USA cars had a lifetime seatbelt warranty.
Many dealers will warranty the buckle for the airbag light problem.
Many others won't.
TECHNICALLY, it is not a warranty matter.
Some dealers still cover it anyway.
HINT: If the buckle cannot latch, that is definitely a warranty matter.
Read your owners manuals. Page 309 in a manual for a 4 door.
Might be worth a few phone calls.
YW
Old May 4, 2012
lollygagger's Avatar
Person
lollygagger has a spectacular aura aboutlollygagger has a spectacular aura about
The seat belt sensor should be covered by Honda. I've seen it floating around here somewhere that they replace this free of charge. Getting them to check it is another story. They charged me to scan it and my issue was the SRS module. I never replaced it, someone hit me at 30...combined speed maybe 40 and the airbags deployed without a hitch.
Old May 4, 2012
amber09's Avatar
amber09 is an unknown quantity at this point
I had the exact same thing happen in my 2002 Civic. If the code is for the seatbelt then the Honda dealer will fix it for free because seatbelts have a lifetime warranty. However, if they run the code and find it not to be the seatbelt it is a $100 fee for running the test, on top of the cost of the repair. When I got mine fixed however, they said 90% of the time it is the seatbelt.
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
