Limp
Old Dec 27, 2011
azalleyrats's Avatar
BigJedi
azalleyrats is an unknown quantity at this point
Unhappy Limp
OK, I was driving along like always and all of a sudden my 01 EX just lost power. It would run but would cut out at about 1300 or so RPM's and it had an engine light. I shut it down to call someone for help and then just for the heck of it started it back up and it ran fine. I got home and ran the code and my scanner said TDC sensor. I cleared the code and I had no more problems for like 4 days then all of a sudden it did it again.
I got it home and tried to run a scan again and it wouldn't connect. I began my search and found another ECU with the exact numbers as mine, installed it, and had my guy come out and reset the peramiters and program my key.
The car started right up with no engine light and ran perfect.
Again I had no problems but then about a week or so later IT HAPPENED AGAIN!!! except this time the battery light came on while it was still running OK then went out and the engine light came on. Now my scanner won't connect again and just like before, as it tries it has words at the bottom of the screen that keep flashing from one to another then never connects.
When I start the car now, I can hear the ECU clicking and everytime it does, the dash lights switch from having battery light with no engine light and the gauges all work and it runs good to having engine and no battery and the gauges don't work and the engine limps.
I have an aftermarket alarm that has been on the car for years with no problem and it had an aftermarket stereo that I changed with a different aftermarket stereo right before this started happening.
My first thought would be to immediatly blame the new stereo but I disconnected it and pulled it out with no help, and I'm leary of jumping to that conclusion unless there is a way I can check it. spending $100 to $200 for a computer then another $100 to get it programmed is a little to expensive to trial and error with.
PLEASE HELP!!!
Thanks,
Eddie
Old Jan 1, 2012
BigJedi
Exclamation Re: Limp
So I see there have been 92 people on looking at my post. Take away the 6 times I've looked at it that STILL leaves 86 people.
Does no one have an opinion or idea about this?
Do I need to rip out the aftermarket alarm that has been in there for quite a long time? The aftermarket stereo maybe?
PLEASE someone help!!!
Old Jan 1, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: Limp
Your TDC code should have been your first test. Get a HAYNES or CHILTONS manual and follow the directions.
I took the time and did a search and found the nice Honda Manual that usually cost $150. It is search friendly and takes you step by step for every test you can imagine.
I cleared the code
Why? thinking the problem would go away? Don't just clear codes without doing tests for them.
Did you check the fuse for the ECU? Was your ignition in the right spot? Did you think it might have been your scanner?
Why did you go this route? because of your scanner not connecting? see above ???
Because you never fixed the problem!!
Possibly altenator
Possibly altenator wasn't charging the battery, it died, scanner won't connect when your battery is dead.
If you get the car running again, hook your scanner up again and see if it works.
This doesn't make any sense, clean it up, and re-post
Word of advice man, just because you see 86 people look at your post doesn't mean they are not helping...a lot of them could be guests or people who don't know how to help and instead of filling the post with 86 IDK, they simply don't say anything....
Old Jan 1, 2012
Re: Limp
have you ever solved the TDC problem first and foremost before changing the ECU? ...
and not connecting could be also damaged wiring...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Khmi
Jun 23, 2015 11:03 PM
