license plate light problem!!!
Old Aug 29, 2011
rberrey's Avatar
rberrey is an unknown quantity at this point
Unhappy license plate light problem!!!
i realized my license plate lights and truck lid lights are both not working, but brake lights, reverse is all working fine...i replaced the bulbs, and checked the fuses and there all good...anyone have any suggestions!!!!..thanks
Old Aug 29, 2011
Re: license plate light problem!!!
check the wire loom that is tied to the trunk arms. many times the wire will get pinched from opening the trunk too much and short out or break.
Old Sep 2, 2011
rberrey's Avatar
yea there was 2 wires that broke, thanks for the help!
Old Sep 2, 2011
CraigW's Avatar
I found a tsb on this one time a while back (after already fixing the issue on my 05)
Pretty simple fix though.
Don't want to be minus those plate lights.
Old Oct 16, 2019
Countryboy1977's Avatar
Countryboy1977 is an unknown quantity at this point
Having the same issue just Google and found that the reverse lights a section of the tail light in the lid and tag lights. But the problem I'm having is section of the lights in the lid and tag lights are not working. Reverse lights work though. When reading your comment I went out to try to look at the wires but they are sealed up in a waterproof wrap of some sort. How do I get this off of there to where I can look at the wires. I know she'll have them have a split to where you can peel the wire out of them but this thing is completely sealed. want to kind of refrain from trying to cut it open afraid of cutting wires message me back directly if you can my email is dwcountryboy39@gmail.com. thank you
Hrddrvs
Apr 11, 2015 11:22 PM
technosilver
Nov 16, 2001 07:00 PM
wawacito
Nov 5, 2001 03:32 PM
sonsonzai
Nov 4, 2001 12:52 PM
