Timing Belt + General Maint Questions
Old Apr 1, 2011
  #61
mikey1's Avatar
Re: Timing Belt + General Maint Questions
Originally Posted by RemyL31
Driving to a shop and having them crack the pulley bolt sounds like a hassle to me. If I were you and didn't have the the special tool or air tools, I would just buy the special tool. You will probably end up having to pay the shop to loosen the bolt for you. (you can find the tool for just under 30 bucks shipped on the internet)
i will buy the tool anyway....i am still concerned that i might not be able to get the bolt off even with the tool....i realize i will have to pay the shop....that doesnt bother me....
Old Apr 1, 2011
  #62
RemyL31's Avatar
RemyL31 will become famous soon enough
use a 1/2" or larger breaker bar and find a pipe that fits over it for more leverage
Old Apr 1, 2011
  #63
mikey1's Avatar
thanks.....
i have been there and done that with many bolts....i have a 4 foot cast iron sprinkler pipe that i keep for these reasons to put over my ratchet....but even with that i am still not sure....never tried this bolt before but from what im reading its horrid....or maybe everybody who says that is not as experienced as me....or thats what im hoping....lol
Old Apr 1, 2011
  #64
BlueEM2's Avatar
Whachya lookin at?
Mine honestly wasnt too bad... I had a LOT of flex my my 36" breaker bar though No additional pipes required.
Old Apr 1, 2011
  #65
RemyL31's Avatar
I think my breaker bar is only 18" but my pipe is around 36
Old Apr 1, 2011
  #66
BlueEM2's Avatar
Whachya lookin at?
I was putting all me weight into it and the bar was flexing to the max id say... so... i thought if i jump on it either the bolt will break free or the breaker bar will snap.. I jumped on it heard "SNAP", luckilly it was the bolt. I had to do that three times to actually free the bolt up!!!
Old Apr 1, 2011
  #67
good it was the bolt, not ur ***** over the bar
all depends on luck, i guess. some of the ball joints in my case were a pain, tool or not... u-tube method almost killed me had to repair the wall...
Old Apr 1, 2011
  #68
BlueEM2's Avatar
Whachya lookin at?
Wow... the youtube method is the one I used with success... my bolt only had 80k miles on it though. I do believe the more miles the harder it is to free it
Old May 2, 2011
  #69
misterzee's Avatar
misterzee is an unknown quantity at this point
'Just did mine on a 2001 I recently picked up used. The car has 182,000 miles, and i know the belt was original, and surprisingly, everything under that cover looked good. I think the mfgrs build in a lot of margin there, but why tempt fate specially on an interference engine. The " recommended " method of removing the crank bolt worked perfectly. Replacing the plugs and setting up the valves gave a surprising improvement in the engine smoothness, and im looking forward to see how much it helps the mpg.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
