Vtec solenoid help!!!!
Old Mar 17, 2011
GFreakSI's Avatar
GFreakSI is an unknown quantity at this point
OKAY!!
So I know there are a lot of ppl who know their SHIZNITS on this forum.
I've been getting that stupid safe mode+engine light on issue (I did my research). Yes, the motor doesn't let me rev pass 4000 rpm.
I've got a new solenoid on order that I bought for like 40 bucks.
So!! MY QUESTION!!:
Where the F*** is the solenoid located in the engine?
Can anyone post up a picture and highlight where the the solenoid is generally located?
I'll know how to take it off once I locate it!
Engine: stock D17A2
this isn't my particular motor but...
THANKS GUYS!!!!
GFreakSi
Old Mar 17, 2011
Re: Vtec solenoid help!!!!
look in back left corner, you cant see it in that pic. if you have stock intake, you may need to remove it to be able to see the solenoid.
Old Mar 17, 2011
GFreakSI's Avatar
Thanks man!
I'll take a look when I get the chance!
I thought so too. The stock intake is fairly large.
Old Mar 17, 2011
apeterson's Avatar
apeterson is an unknown quantity at this point
you dont have to take the intake off at all. just three bolts (10MM). the bottom one you only need to loosen as it is slotted.
in your pic you posted it is on the left side, right where the engine wiring harness is draped over it.
Old Mar 17, 2011
7genmarathon's Avatar
7genmarathon is an unknown quantity at this point
Vtec is circled in red for reference.
I take off the air filter, just to make life a little easier on my hands. Off or on you can get it
Old Mar 17, 2011
and this is how it look in a 6th gen engine
https://www.civicforums.com/forums/2...9181-what.html
Old Mar 23, 2011
GFreakSI's Avatar
Thanks a LOT man!
Funny thing is, (and I heard of this solution when I was researching)...I got an oil change and it fixed my problem with the engine light coming on.
However, I received the solenoid last night. Still gonna replace it.
ONCE AGAIN, THANKS!!
Old Mar 23, 2011
meaning your oil was low?
Old Mar 24, 2011
TRIZ's Avatar
Solenoids almost never go bad, but thats really weird oil had something to do with it..
Old Mar 24, 2011
GFreakSI's Avatar
It wasn't low.
Just haven't changed it for a while.
however, just today...the engine light came back on...
I'm gonna change the solenoid and let you guys know what happens!
Old Jan 4, 2013
bmnot's Avatar
bmnot will become famous soon enough
So, I don't mean to necropost of thread hijack, but this is the thread that keeps coming up no matter what I type into google. Where does one get a new solenoid? And for such a low price?
Whenever I even so much as google the part name, most things come up with only the gaskets, except for this which has way too much involved, and for $203.
I appreciate any direction you lovely experts can provide.
(PS: I also got the oil pressure light - cured by tossing in a few quarts of oil - in addition to my check engine light. Will be taking it to bro's house to use his jack stands for a full oil change in the morning, but want to be prepared.)
Old Jan 5, 2013
Cheapest I found was $95.35 shipped on ebay
http://www.ebay.com/itm/2001-02-03-0...ee508c&vxp=mtr
brand spankin new for $152.47 + shipping at majestic honda: http://www.hondaautomotiveparts.com/...28SOHC+VTEC%29
#9 on the drawing, part number 15810-PLR-A01:
Old Jan 18, 2013
trikky74's Avatar
trikky74 is an unknown quantity at this point
I put 200 miles a day on an '05 civic driving to and from work and I run full synthetic oil.
When my oil inevitably gets low a rev limiter kicks in that won't allow the car to rev past a certain point until the oil is changed/replaced.
It's saved me from some expensive repairs as my engine has crept into the higher mileage range.
Old Jan 18, 2013
A smart monkey* would be checking and adding oil long before the car tries to tell you there's a problem.
I think the owners manual says to check oil at every gas tank fill up.
Once an engine has been run super low on oil, they generally consume oil even more rapidly from then on.
*Smart monkey is what some of us are called at work.
Old Jan 18, 2013
trikky74's Avatar
I totally agree, I was merely commenting on the fact that there is in fact a rev limiter function built into the '05 civic that kicks in when oil drop below a certain level.
Old Jan 18, 2013
FYI: The engine and computer have no clue how much oil is in it. There are no oil level sensors to send that information.
The reality is that it does this when there is insufficient OIL PRESSURE to support VTEC operation.
There must be over 40 PSI at the time the VTEC tries to operate. If not, the CEL turns on and RPM is limited as a failsafe.
Loss of oil pressure is bad, very bad. (Much like blood lost from your body. Drain 3 quarts of blood out and try to run around the block.)
Low oil level is the most common cause of pressure loss, but not the only possible cause.
HTH
h4ldol
Apr 24, 2017 08:16 PM
Solo Flow
Oct 4, 2015 07:52 AM
senicalj4579
Oct 2, 2015 10:03 AM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
