led cup holder?
Old Apr 10, 2009
KevKevBarkBark's Avatar
KevKevBarkBark is an unknown quantity at this point
led cup holder?
i was just wondering how one might happen to pull off leds in the cup holders...has anybody done it?
Old Apr 10, 2009
TRIZ's Avatar
Re: led cup holder?
Tap them to the accessor/cig lighter power.. wire a switch to wherever if you want.. drill some small holes in the cup holder and wire the LED's. Simple. Only tricky part is if you pick individual LEDs vs a pre fabbed string is the resistance
Old Apr 10, 2009
lowlife9's Avatar
Re: led cup holder?
or you can get those getto battery powerd led strips at the auto parts store.
Old Apr 10, 2009
CraigW's Avatar
Re: led cup holder?
I have one in each cup section, they are on the shifter side facing forward so you can't see the distraction of the bare LED. They come on when car is on.
Old Apr 10, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: led cup holder?
Don't run the power to the cig lighter. That circuit is designed to pull very little amperage and while led's don't draw much its still better to put them on a dedicated circuit. I'm assuming you actually know how to the wiring. As for how to mount the leds. Get a few led holders, drill ~3 holes in the bottom of the cup holder, put the led holders and led's in there. Then take a round piece of acrylic and sand the bottom of it with 600 ish grit or higher paper to frost it. Then lay it over the leds. It will make it glow but keep the glare out of your eyes. Check out oznium.com they have some great pics.
Old Apr 11, 2009
Jp7's Avatar
Jp7
Jp7 is an unknown quantity at this point
Re: led cup holder?
its an easy mod, you can buy parts and see examples on oznium.com
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
Jrosa
Sep 14, 2015 08:24 PM
