removing fog lights
Old Mar 12, 2009
KevKevBarkBark's Avatar
KevKevBarkBark is an unknown quantity at this point
removing fog lights
k so i have an 01 civic ex coupe and i have some yellow fog lights that i want to install but i have one problem: the previous owner already installed some shitty universal foglights that he wired into the headlight switch
ive wanted to take them out but im worried about any sorts of problems
also im new to cars so like i dont really know much about the electrical stuff (i.e. tapping into wires, relays, etc)
the foglights turn on when i turn my headlights on and there is a relay for them if that helps any...
what would be the proper procedure for taking these out?
Old Mar 12, 2009
BigVic4545's Avatar
BigVic4545 is an unknown quantity at this point
Re: removing fog lights
He probably tapped into the headlight wires....look through the head light wires and untap the wires....make sure you disconnect the battery.
Old Mar 12, 2009
k well how should i untap them? do i just cut them and tape them up or something?
Old Mar 13, 2009
BigVic4545's Avatar
well they should already be taped up...first you have to locate the wires that control the headlights....from there you should find a wire or two from the foglights taped up...just remove all the wires from the fogs...its kinda easy but hard to explain through words.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
