Tranny swap need help
Old Nov 16, 2008
01_EM2's Avatar
01_EM2 can only hope to improve
has ne one attempted to do a auto to manual swap on an em2? is there a diy cuz i havent found one. ive read up that you can mate a d16 tranny to the d17 block so im wondering if it can be used or what i need to get this done please help
Old Nov 16, 2008
greeen01civic4d's Avatar
Re: Tranny swap need help
dude u gotta search, ull need cables, slave cylinder, manual ecu, master cylinder, trans, clutch, flywheel, associated bearings, shifter, anything else anyone? oh yea, pedals
Old Nov 17, 2008
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
center console... and there is something close to a diy over on 7thgenhonda in the swap forced induction section... its still in progress though.
Old Nov 19, 2008
01_EM2's Avatar
well i went to the junk yard today b4 even seeing the responses from you guys and i picked up the clutch pedal and clutch resovoir and naster cylinder. and the shifter assembly. and the manual ecu all for 49 buks.... so all i need left is the tranny and axles. obviously i know i need a clutch and flywheel that was a no brainer but do i need both axles or just one cuz i thought that one axle was able to be interchangeable to the 5speed swap
Old Nov 20, 2008
01_EM2's Avatar
bump ne one know about the axles??
Old Nov 21, 2008
01_EM2's Avatar
^^^bump for question
Old Nov 21, 2008
baron340's Avatar
http://www.7thgenhonda.com/forum/showthread.php?t=8227
go read that... it should answer all your questions even though he isn't done yet.
Old Nov 21, 2008
supafil25's Avatar
supafil25 will become famous soon enough
i made a diy still workin on th car tho
on the better forum
http://http://www.7thgenhonda.com/fo...ead.php?t=8227
Old Nov 22, 2008
01_EM2's Avatar
didnt list ne parts!! i already installed my clutch pedal and master cylinder in my car. i have the ecu from a 5spd and the shifter. i know i need the linkage slave cylinder which i forgot to grab leaving the junk yard.... alot of extra work on removing the harnesses and dash??!!!
Old Nov 24, 2008
supafil25's Avatar
its a pain but not that much work. you need to find hidden screws.
parts
trans
flywheel
clutch
master / slave cylinder
clutch lines
subframe
axles
ecu
engine harness
shifter and cables
little bits and pieces from hondapartsunlimited.com
Old Nov 24, 2008
supafil25's Avatar
ppl said you dont need to replace the dash harness. but i did.
Old Nov 29, 2008
01_EM2's Avatar
why does the engine harness and subframe need to be swapped??? just curiouse as to what the difference is between them are
Old Nov 29, 2008
supafil25's Avatar
the front and rear engine mounts change so you need the subframe. and the manual trans has only 2 connectors instead of 6. you can prolly run with auto engine harness just have to deal with the check engine light.
Old Jan 8, 2009
01_EM2's Avatar
the rear engine mount wouldnt change because the mount is connected with the motor not tranny. the only one i might see a problem with is the front mount but we will seee cuz ima gonna opt not to get the subframe. unless theres is a pic wer i can see the big differences and it not working
Old Jan 8, 2009
01_EM2's Avatar
also i read on your thread and it looks like your going through with not having to get the ecu flashed that would be great info to know if you could sharew once you figure it out
May 4, 2016 07:14 AM
2005seTO
Aug 18, 2015 12:45 PM
OldschoolCool
Aug 17, 2015 05:05 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
