need help with map sensor
Old Dec 7, 2007
puertorro's Avatar
puertorro should not be trusted
i already finish install a emanage on a civic 03 but i got a qustion about the airflow input and output . here is the list of the pins but im not sure where the input and output wire goes
please help
2001-2003 Honda Civic ECU Wiring
Connector A (31 Pins)
1-blk/wht-Primary O2 sensor heater control
2-yel/blk-Power Source
3-yel/blk-Power source
4-blk-Power ground
5-blk-Power ground
6-wht-Primary O2 sensor
7-blu-Crankshaft position
8-yel-Sensor return volt
9-red/blu-Knock sensor
10-grn/yel-Sensor ground
11-grn/wht-Sensor ground
12-blk/red-Idle air control valve
13-wht/blk-EGR Valve position VTEC ONLY
14-blk/wht-Secondary O2 sensor heater control
15-red/blk-Throttle position sensor
18-wht/grn-Vehicle speed sensor
19-grn/red-MAP Sensor
20-yel/blu-Sensor Voltage Supply
21-yel/red-Sensor Voltage Supply
23-brn/yel-Logic ground
24-brn/yel-logic ground
25-wht/red-Secondary O2 Sensor
26-grn-Top dead center sensor
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
Connector B (24 Pins)
2-yel-Fuel injector 4
3-blu-Injector 3
4-red-Injector 2
5-brn-Injector 1
6-grn-Radiator fan control
7-red/blk-A/T Pressure control solenoid valve A
8-red/wht-Engine Coolant sensor
9-blu/blk-VTEC Oil pressure switch VTEC ONLY
10-wht/blu-Alternator L Signal
13-wht/red-Alternator FR Signal
14-blu/red-EGR Valve VTEC ONLY
15-grn/yel-VTEC Solenoid valve
16-blk/red-A/T Pressure control solenoid valve B
17-red/yel-Intake air temp sensor
18-wht/grn-Alternator control
21-yel/blu-EVAP Canistor purge valve
Connector C (22 Pins)– AUTO TRANSMISSION ONLY
1-wht/blk-A/T Pressure control solenoid valve A
2-yel/blu-Torque converter clutch solenoid
4-grn/wht-Shift solenoid B
6-blu/blk-Shift Solenoid A
7-wht/red-Mainshaft speed sensor
8-brn/wht-A/T Pressure control solenoid valve B
9-red-Position switch D3
10-wht-position switch R
11-blu-position switch 2
12-blu/wht-position switch neutral or park
14-grn-countershaft speed sensor ground
15-blu-countershaft speed sensor
18-blu/yel-position switch D3 or D
20-yel-position switch D
21-wht/grn-mainshaft speed sensor ground
Connector E (31 pins)
1-grn/yel-Immobilizer fuel pump relay
2-wht/red-Secondary O2 Sensor EX Only
4-pnk-Sensor ground
5-yel/blu-Sensor voltage source
6-blk/wht-Secondary O2 sensor heater control EX Only
7-red/yel-PGM-FI main relay 1
9-yel/blk-Ignition input signal
12-blu/orn-Cruise control signal
13-wht/blu-Interlock control unit
14-lt grn-Fuel tank pressure sensor
15-grn/red-Electrical load detector
16-lt grn/blk-Power steering pressure switch
18-red-A/C Clutch
20-blu/red-EVAP bypass solenoid valve
21-lt grn/red-EVAP Canister shut valve
22-wht/blk-Brake pedal position switch
23-lt blu-K line
24-yel-Multiplex control unit comm line
26-blu-Engine speed pulse
27-red/blu-Immobilizer code
29-brn-Service check signal
30-red/wht-Write enable signal
31-grn/orn-MIL or check engine light enable
Old Dec 7, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: need help with map sensor
Airflow input and output sounds like something for a MAF sensor, which we dont have. What are you trying to do with an emanage? It has its own MAP sensor that plugs into the blue box.
Old Dec 7, 2007
puertorro's Avatar
sorry men i run a rx7 turbo 2 i just bought a civic 2003, and i have some things i took off from the rx7 like the emanage. im just putting some gas and air into the car cuz this engine suck.
the problem is that the diagram is not compare with my ecu
u seems like u know a lot about this cars please i will send u a private with my msn (please help me out) thanks
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
aultman1990
Jul 9, 2015 08:27 PM
CivicsClass101
Jul 9, 2015 11:14 AM
