8th Gen 2006 - 2011.
spark plugs?
Old Jan 7, 2018
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
spark plugs?
say guys when do you no when its time to change spark plugs ? bcause I'm thinking of doing mine thx.
Old Jan 7, 2018
CraigW's Avatar
Re: spark plugs?
~ 100K miles.
I always choose OEM for replacements.
Old Jan 7, 2018
Re: spark plugs?
hey there CraigW well i got about 114,000kms on it right now dont no if they ever were done. however it always starts up even in the frigid Cold we here in Canada been having -20 has been the norm for some time now my question would be does changing to new oem spark plugs recomended get my engine to start quicker in colder temps ??
Old Jan 7, 2018
Re: spark plugs?
ONLY if the old spark plugs were causing a problem.
Old Jan 12, 2018
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Re: spark plugs?
How do You know You ask.? You wont engines computer compensates for any wear on them. 100,000 or so kms
is about the life expectancy of O.E.M spark plugs you dont whant to go any further then there designed Or
You could damage a Coil pack or two.
Old Jan 13, 2018
Re: spark plugs?
really"? that's news for me brags never thought it could damage coil packs though". thank-You all for answering post
Old Jan 13, 2018
Re: spark plugs?
I always do the minimum changes when getting a new car just in case.
oil, coolant, filters, plugs, etc. Just so i know when they will be due
Old Jan 13, 2018
brags's Avatar
Re: spark plugs?
If there left in there too Long Yes they can damage a coil Pack or two and also corrode threads inside the cylinder head being dificult to remove on the way out listen save yourself the headaches. If Your doubt? Just change them and start with a new proper O.E.M. set for peace of mind. and that way You no there fresh New S/Plugs
Old Jan 13, 2018
brags's Avatar
Re: spark plugs?
Exactly what i would do with any used car...
carter
28
Sep 26, 2010 03:24 PM
JCurry2885
Mar 19, 2008 11:01 PM
MikeyBoy
Jan 26, 2002 06:45 AM
AnotherDopeStyle
Jan 5, 2002 06:39 PM
ACEM2
Bolt-on Engine Performance
Nov 11, 2001 08:36 PM
