8th Gen 2006 - 2011.
2012 civic ATF capacity?
Old Aug 29, 2016
senicalj4579's Avatar
senicalj4579 is an unknown quantity at this point
Could anyone tell me what the ATF capacity is for a drain and fill? I need to know what the book says. 2.9? 2.5?
Old Aug 29, 2016
CraigW's Avatar
Re: 2012 civic ATF capacity?
~ 3qts
I would go with DW1 myself.
Old Aug 30, 2016
The book says a even 3qts? I need the exact amount.
Old Aug 30, 2016
CraigW's Avatar
It will depend on how long you let it drain.....up to 3qts. If nothing else, measure what drains out.
Old Aug 30, 2016
Yes, I did all that and I usually go buy a book for all my cars but there is no Haynes book for my car. Otherwise I wouldn't be asking here what the exact amount in the book says. Anyway...
I found Amsoil's website to have the info copied and states Automatic Transmission, BRZA Initial Fill..........2.5 quarts
I know it will vary but I wanted the correct # for knowledge.
Also, I don't really care to go by how much fluid comes out because I'm not the one who did the service last time. The Honda dealer supposedly did it but its the same people who left the coolant surge tank bone dry. So why would I trust them? Thanks
Old Aug 30, 2016
Use the dipstick as the final measure.
Old Feb 25, 2018
Chris C's Avatar
Chris C is an unknown quantity at this point
Just did mine for first time. I would advise checking level prior to, and if it’s good, measure how much you drain. Point being, there can be variables to how much you drain. In my case, I was just in my garage using a floor jack. Based on the drain plug location, I couldn’t jack front center and still place drain pain pan in the right spot. So I jacked driver side which tilted car towards drain hole and letting more fluid out. Took right at 4 qts all said and done
Old Feb 25, 2018
4 seems like an awful lot, but I've never drained one tilted to the side like that or let it drain for hours. Hope you got the car level before final checking......and when checking the trans fluid the engine must be OFF.
josalvarez
Regular Maintenance
Apr 26, 2020 02:18 PM
prr
Aug 17, 2016 07:09 AM
prr
Aug 16, 2016 04:51 PM
fijiblue05
Air Conditioning
Aug 5, 2016 07:56 PM
Cgreco
Jul 27, 2016 01:07 PM
