8th Gen 2006 - 2011.
windshield washer problems
Old Jan 18, 2010
Adam013085's Avatar
Adam013085 is an unknown quantity at this point
Question windshield washer problems
A week or so ago it got down to single digits and my windshield fluid froze up. No big deal I figure I would wait. Well I put it in the garage and thought I drained out all the old fluid and refilled it with new. Well I guess I did not get it all out because right after I refilled it it quit working. Its been above freezing for over a week now and one day it was near 50 with it being in the 40s every other day. When I try to use it I can hear the pump running but still nothing out. Is it possible to still be frozen still? I was going to take it out and look at the resivoir but apparently honda likes to bury them. I have an 06 civic ex. Any help would be great.
Old Jan 18, 2010
TRIZ's Avatar
Re: windshield washer problems
The washer system is pretty basic. With the bumper off, you have full access to it. Trace the lines and make sure non of them disconnected when they froze.
Old Jan 18, 2010
Adam013085's Avatar
I can do that but that does not really seem logical since they worked til I flushed them then once I added it and tried squirting them again(less than 2 min) it didnt work. When it was coming out it was not at full stream at any of the time
Old Jan 18, 2010
is anything leaking on the ground? its possible you broke the pump when fluid was inside it and expanded while freezing. take off the hoses from the washer nozzles and then run the motor again. see if anything squirts out (hold the tubes away from the car, if its working, fluid will GUSH out). in which case, replace the nozzles since they are clogged.
Old Jan 18, 2010
Adam013085's Avatar
I am going to attempt to look at or fix it today. Not sure how any of it comes apart or anything.
Old Jan 18, 2010
well the hoses just pull off the washer nozzles...
Old Jan 18, 2010
Adam013085's Avatar
But how do you get to the nozzles? Do you take the black piece off that is between the hood and the windshield? How does it come off? is it held in by clips or what? Also where is the washer motor located? is it buried like the reservoir?
Old Jan 18, 2010
the nozzles do not even have to come off the car to test, just pull out the hoses. but the nozzles just pop out by squeezing the sides to release the tabs (from under the hood). washer motor is attached to the fluid tank on the outside.
Old Dec 13, 2012
Frank0411's Avatar
Frank0411 is an unknown quantity at this point
Hi. I have a 1998 honda civic ex and i have been having a problem with the windshield washer. Everytime i turn on my headlamps the windshield washer turns on. Can anoyone help me with this?
Old Dec 25, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Those are two separate sticks on the steering wheel column thing, not sure how connections would cross like that. Headlights=left windshield wiper stick on right
BTW @OP, use rain-x 2 in 1 -25 F windshield washer fluid
Domindart
Jun 4, 2015 09:20 PM
shindrome
Exterior
May 5, 2015 02:50 PM
DaveyD
Mar 28, 2003 12:28 AM
KOPSEAL
Jan 1, 2002 03:23 PM
blackbullet
Dec 1, 2001 03:44 PM
