8th Gen 2006 - 2011.
0w20 vs 5w20
Old Oct 18, 2008
oconn11's Avatar
oconn11 is an unknown quantity at this point
0w20 vs 5w20
Has anyone tried using 0w20 instead of 5w20 in their Civics? Has it improved gas mileage? Anything else?
Thanks!
Old Oct 18, 2008
Re: 0w20 vs 5w20
i doubt you will get more than 1mpg if even that. its mainly designed for weak hybrid engines that do not see very harsh conditions. i would recommend going to a 5w20 tho if you have a hybrid and run it hard or drive in hot weather 80F+
for a regular civic, i would actually suggest going to 5w30. the thinner the oil, the more it will fall apart at higher temps and cause excessive wear on the motor. also being as thin as it is, you will be dry starting the motor every day since most of the oil will have fallen off into the pan.
totravska
Aug 30, 2015 12:02 AM
Protan988
Feb 18, 2010 07:13 PM
zen_master
Jun 12, 2005 12:43 AM
JCap
May 9, 2004 03:51 PM
StealthBlack
17
Apr 28, 2003 05:24 PM
