i need help installing a remote starter on my 07 civic si
Rep Power: 0 i need help installing a remote starter on my 07 civic si
i got a new 07 civic si sedan and want to get a remote starter installed. i had on on my old car ( 01 saab 95). but i was told by my guy installin it that he needs specific instructions. Can anyone give me step by step instructions on how to install it including bypassing the clutch and everything else i need?
thanks in advance
thanks in advance
I need a drop
Rep Power: 233 dont bypass the clutch, whatever you do. take it to a professional shop. if the person installing it now needs specific instructions, i wouldnt let him put it in.
I need a drop
Rep Power: 233 ^ I wouldn't go as far to say that. It's more of a comfort feature. If you don't want your *** to be freezing when you get in, or burning up when you get in, it's nice.
Rep Power: 0 its not pointless i was jw if anyone has instructions on how to do it cause i have a professional guy putting it in he just wont do it on manual transmission unless he has specific instructs because if he messes up his company could technically be screwed
I need a drop
Rep Power: 233 Take it to a different shop. Those are the instructions. I wouldn't want a guy installing my stuff that needed directions that I have to hunt down for him. Take it to another shop and see what they say.
I thought it could only be done on the very few manual trans. vehicles that had didn't require the clutch being pressed to start it, like some of the old 'Yota trucks. I was told by a local shop that other than that, it can't be done. And say you do get it, you'll have to leave your vehicle out of gear when parked, and you can't ALWAYS rely on your parking brake alone...I've learned that from experience, lol, my truck stays in gear when parked now.
omgwtfbbq mod.
Rep Power: 287 You can do it to any car. Some cars require a module and some dont. At Best Buy (where I work for my 2nd job) they had to do a module bypass on my buddies 350z. It can be done, it just depends on the parts needed.
Rep Power: 0 The clutch interlock switch can be very easily bypassed in a matter of about five minutes. The procedure is indeed very straight-forward. After removing the plastic trim over the pedals, simply disconnect the clutch interlock switch from the wiring harness and jump the harness end, so that the circuit is always closed. I had done this one my 2005 for the purpose of more easily starting the car without having to sit in the driver's seat.
The interlock mechanism itself is a simple OPEN / CLOSED push-button switch that's engaged only when the clutch pedal is pushed to the floor. Because the interlock switch operates independently, such a modification will not affect the vehicle's operation during regular driving (the clutch position sensor that functions to inform the ECU as to when the clutch is engaged / disengaged is another switch altogether). However, if attempting this modification on your own car, be mindful that there are TWO clutch switches -the interlock switch, which is triggered (usu. CLOSED) only when the pedal is pressed all the way to the floor, AND the clutch position switch, which is triggered (usu. OPEN) after the clutch has been depressed only 1 inch or so.
That said, anyone considering this modification should use extreme caution. Vehicle manufacturers install clutch interlock switches on all manual transmission vehicles as a safety precaution -and with good reason! Even with the parking brake in place, the vehicle's starter has enough torque to launch your car unexpectedly forward or backward, potentially into another parked car, a structure -or even worse -a pedestrian! Due to this risk, I highly doubt that you will be able to find a reputable shop that will make such a modification to your car, as they could be liable for any ensuing damages that resulted from such a mod.
Moral of the story... if you really have to have a remote start on your manual transmission vehicle, you're going to have to install it you self [or find someone with the ***** / stupidity to do it for you].
PLEASE BE CAREFUL.
PLEASE BE CAREFUL.
Rep Power: 0 Re: i need help installing a remote starter on my 07 civic si
R/s on a manuel car can be done and be done safe you just need to have a magnetic switch on the shifter so that if the car is not in nutral the car wont start so that will avoide you accdently starting your car in first gear or at least at thats what my friend did.
Rep Power: 239 Re: i need help installing a remote starter on my 07 civic si
I always recommend an r/s designed for manual (compustar for example) or the addition of the Peripheral NSS to any other r/s.
carhag2000
04-25-2015 01:33 PM
Linda0818
04-23-2015 11:30 AM
SSMatey
04-13-2015 06:09 PM
gabrown2
04-11-2015 08:22 PM
