8th Gen 2006 - 2011.
Honda defroster reprogramming
Old Feb 7, 2018
  #61
Re: Honda defroster reprogramming
Originally Posted by bkv007
I have done the reprogramming and it works.
But I hate having to turn the A/c off every time i hit the defrost function during the winter.
I thought that was the whole point of doing this procedure. You now have the option of turning the AC off in defrost mode.
Is there a way to pull the fuse (Fuse #20 = MG clutch) or relay connected with the a/c compression to fully stop it from functioning at least for the few months in the winter time????
Not sure where you live, but there are times AC is really freekin handy for clearing a fogged windshield quickly, even in the dead of winter.
Relay with single snowflake was pulled but compressor still turns on.
Push the button on the dash to turn the AC off. You said the programming mod did what it was supposed to do, so use it.
Or does the AC still run even after doing that? Does the compressor continue to run even when the entire control panel is turned off?
Please help
What year is the car?
Old Feb 8, 2018
  #62
CraigW's Avatar
Normal operation when changing modes for compressor to re-engage (even my '13 w/ CC still does)
I set mine at floor, DEF and leave it all winter.... Till I bump that big *** button, and have to reset everything back the way it was.
CarStuff
Dec 6, 2020 12:52 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
Bartkat
20
Feb 19, 2002 01:29 PM
clockwerx
Dec 13, 2001 12:39 PM
