noob Q about throttle cable
Old Apr 10, 2003
R3DL1N3's Avatar
where the hell is it?? i want to do the DIY adjusting thing but cant figure out where the **** it is. i mean, im sure its around the throttle body...christ someone help a noob out.
Old Apr 10, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
It is a small cable right behind the throttle body and a little bit toe thr right of it
Old Apr 11, 2003
LiKEaFeRiO's Avatar
I remember when we all discussed this way back then.
All it does it basically higher your idle speed a little bit.
You'll risk losing a slight bit of gas mileage.
And if you do try this make sure to mark where the bolt is with the nut just in case you want to change it back to factory specs.
Old Apr 11, 2003
jungleboogie's Avatar
jungleboogie is an unknown quantity at this point
yes... and it doesn't matter cuz when you floor it... your throttle opens up all the way anyways
Old Apr 11, 2003
MaddonE's Avatar
MaddonE is an unknown quantity at this point
i adjusted my throttle cable and i felt a difference but only for a couple of days, then it went back to normal
Old Apr 11, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
I tell you what...I did it and I would never go back. I hated the delay in the cable ever since I got the car. Now it feels right. My idle hasn't changed at all, you just have to adjust it right.
Old Apr 11, 2003
Xplocv2k1's Avatar
myspace.com/misterwarren =]
Xplocv2k1 is an unknown quantity at this point
It feels like it goes back , because u get used to it. . . i thought mine had gone back , but i checked , and it was still set
Old Apr 11, 2003
gotti's Avatar
I adjusted mine. Im not gonna say it gained anything, because it didnt, but i like how the accelerator doesn't have a lot of play in it anymore. I like things tight
Tyler93
Mar 20, 2016 09:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
