srs light
Old Mar 2, 2003
Island2K2's Avatar
Island2K2 is an unknown quantity at this point
srs light
my car got flooded 2 months ago so i took out the seats and removed the carpet to dry it out now my srs light wont cut off and i dont wanna take it to honda cuzz i will be outta a ride what do i do??
Old Mar 2, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Check and see if the connector is plugged in?
That would be the first thing I would try. Maybe the water messed it up. I don't see why a 1/2 hour trip to Honda would hurt so much, but whatever...
Old Mar 3, 2003
OmegaStauf's Avatar
OmegaStauf is an unknown quantity at this point
Have you reset your srs light? I think once it's "tripped" it has to be reset. If whatever "tripped" it in the first place is ok now... resetting your SRS light should do the trick.
Old Mar 3, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
Try to reset the light yourself using the DIY becuase if you take it to Honda they will most likely make you leave it there all day becuase they have to run a ton of codes into it to figure out what set it off, so it would be easier and faster for you just to try it yourself, and if it keeps comming back on then you should take it to the dealership and have them take a look at it.
Old Mar 3, 2003
Island2K2's Avatar
i checked all the yellow plugs and fuses that go to the air bags so now ima try to reset it......
Old Mar 3, 2003
666's Avatar
666
666 is an unknown quantity at this point
Mine came on when I had the seat out and I started the car. So I brought it to Honda and it took about 5 min. to reset at no charge. Just tell them you had the seat unplugged and the light came on and you need it shut off. They should help you.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
