Question on ignition
Old Jan 22, 2003
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
ok im looking to build a turbo kit for an 02 civic ex 5 spd. i have made an intake manifold and have ordered new injectors, fuel pump, rail, etc. ive got all my plumbing figured out and i have one question does anyone know what will work for an ignition retard before i try to hack something
Old Jan 22, 2003
Grey's Avatar
DIY King
What psi will you be runnin'? One dude on this site is runnin' 8psi with no ignition retard. I would get colder plugs, but that should be enough for 8psi. If you're planning on going higher, then I'm not sure what you could do? I guess you'de have to wait for the AEM EMS to come out for our cars (that is if it isn't out already). I know that it can control anything and everything. Programming it is the hard part though.
Old Jan 22, 2003
02fpcivic's Avatar
i was looking to run about 5-7 with about 8.5:compression can i go more with low compression pistons also plan to buy a apexi s-afc im trying to keep everything simple and professional i run a small fab shop and plan to make a tubular s/s header and all polished s/s plumbing, gas purge tig welded. ive made polished s/s valve cover trim that takes place of the honda plastic cover but it uses the factory retainers the car is in a million pieces with only 3800 mi on it so if and when i get it back together ill post some pics it should be pretty hot for a sohc motor
Old Jan 22, 2003
Grey's Avatar
DIY King
Check out my little Turbo DIY: custom turbo parts
It's not perfect, but it may give you some ideas. I need to update it 'cause the whole 3-4psi thing without any fuel system mods is very hypothetical. Insane is probably a better word. Disregard that part of the "DIY".
Anyway, you don't need to run lower compression if you only plan to run 5-7psi. As I said, one dude is running 8psi (although not all the time) without any internal modifications.
I would also reccomend reading Maximum Boost by Corky Bell. It really opened up my eyes to all of the little nuances of turbo's.
Old Jan 22, 2003
Sim012's Avatar
Sim012 is an unknown quantity at this point
Quote
[hr]Originally posted by: Grey
[hr]
nice shirt hehe
Old Jan 22, 2003
Baghead's Avatar
Baghead is an unknown quantity at this point
would retarding the timing matter since we have sohc? oh yea and id pimp that shirt. has to be in blue though.
Old Jan 22, 2003
02fpcivic's Avatar
yeah it still does cams and valve timing are different then ignition timing but heres another question if vtec means Variable Timing and lift Engine Control does that mean cam timing or ignition timing?
Old Jan 22, 2003
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: 02fpcivic
yeah it still does cams and valve timing are different then ignition timing but heres another question if vtec means Variable Timing and lift Engine Control does that mean cam timing or ignition timing?[hr]
Yeah, cam timing. Although... I bet the ECU changes the ignition timing when "VTEC kicks in". Actually, it changes the ignition timing by reading the knock sensor (I think). Try an experiment... Turn on your car and rap on the motor with a hammer. You don't have to hit it hard. Just keep tapping it and see it the engine sound changes. This might be more effective on the warm-up cycle since the rpm's are higher. It'll be less noticeable if the rpm's are really low. Anyway, just babbling...
Oh yeah, thanks for the compliments on my shirt. It is kinda bling bling, right? [IMG]i/expressions/laugh2.gif[/IMG]
Nah, actually it's the shirt I wear when I work on my car.
Old Jan 22, 2003
Baghead's Avatar
Quote
Quote
Nah, actually it's the shirt I wear when I work on my car. [hr]
i still got a flannel shirt (blue) that i wear from time to time when i wake up and i grab something to wear around the house.
anyway, i digress. 8 psi but i never read anything about return fuel line....gotta look into how he pulled that off.
Old Jan 23, 2003
Grey's Avatar
DIY King
Ooh ooh! I know, I know!
He used an extra injector and an FMU to control the injector. I'm not sure what the FMU is hooked up to, but it's at least hooked up sense boost at the BOV. Ideally it should be hooked up to as many other sensors as possible. Oxygen sensor, engine rpm, EGT sensors, and tra la la la la...
Old Jan 23, 2003
Baghead's Avatar
Quote
He used an extra injector and an FMU to control the injector. I'm not sure what the FMU is hooked up to, but it's at least hooked up sense boost at the BOV. Ideally it should be hooked up to as many other sensors as possible. Oxygen sensor, engine rpm, EGT sensors, and tra la la la la...[hr]
aight thanks for the info.
civic98?
Aug 13, 2015 01:32 AM
sch2cm
Jul 21, 2015 09:58 PM
emich
Jul 20, 2015 08:42 AM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
cukaracha
Jul 17, 2015 05:48 PM
