tyc projector ?
Old Jan 10, 2003
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
tyc projector ?
i just installed my tyc projectors and noticed little "dots" were the low beam projection is. is this normal or is there moisture in there? also, i got new hyperwhites, 12v 55w, to replace the H1's that came with the projectors, but could not put them in because 1 bulb wouldn't come out of the socket. does anyone know what i can do to take it out?
Old Jan 10, 2003
Samari's Avatar
For the little dots on your low beam projectors might be water spots or something. You would probably have to take off the headlight cover to white them off. The actually len to the projector. Now taking out the H1 buld shouldnt be hard. There is a little metal locking mechinism that you just push down on and pull out . The bulb should then be free. Not hard.
Old Jan 10, 2003
my2k1vic's Avatar
so the dots are not supposed to be there? as for the bulb, i can open the clip and take out the bulb, but i can't get it free from the contector.
Old Jan 11, 2003
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Yeah, I had the same problem - just use a pair of needle-nosed pliers and loosen the bulb from the connector. It's hard to explain, but there's a little piece of the connector that hits a hole on the bulb and locks it in place. If you loosen that from the bulb, it should come free. THen when you put in the new bulb, you might wanna tighten it again so the bulb doesn't come loose and either go dim or turn off completely - this happened to me already, so just a warning ...
Old Jan 11, 2003
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
I got little dots to but its not moisture because my projectors don't fog up
and one time I thought it was moisture which it wasn't and I took them off and blow dryed them for like 10 minutes and low and behold those dots were still their
but it COULD be moisture just go drive the car on a cold day for like 5mins and see if moisture develops inside the projectors and if it does then yep its moisture
but IMO if your projectors never fogged before then its not moisture because I got the same problem as you do[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 11, 2003
my2k1vic's Avatar
thanks guys, i'll try what blue flame said to get the bulb out. as for the dots, i guess its not moisture then because its been raining and they are not fogging up.
wingsfan19
Oct 1, 2015 03:45 AM
marux
Mar 24, 2002 06:13 PM
jimmymingdahai
Mar 20, 2002 04:00 PM
Voiceofid
Mar 12, 2002 07:14 PM
marux
Feb 22, 2002 02:06 PM
