Help, removing/replacing bulbs in projector headlamps
Old Jul 8, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
replacing.removing of the high and low beam bulbs , this brand of headlamp here
Thanks
Old Jul 8, 2002
ironcow's Avatar
ironcow is on a distinguished road
for the low beams:
remove the rubber casing, and if you look carefully there is a little clip holding the bulb in place
push in and then up to unlatch the clip.
shimmy the bulb out of the socket and unplug the wire....
BE CAREFUL NOT TO TOUCH THE BULB ITSELF
replace with the new bulb and plug into the headlamp...make sure it fits snugly or it wont shine correctly.
once it is in clamp it in place and put the rubber cap back on the light
for the high beams:
i have no idea [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 8, 2002
lol, thanks iron cow, hopefully its the same , when u replaced ur lows, did u have to remove the bumper? Do u have a metal like rod up against ur rubber part for your low beam on the driver side?
Old Jul 8, 2002
ironcow's Avatar
yes... and no i didnt remove the bumber although it probly would help...
any way, if you look up and down the metal bar ull see that there are two clips snap them out...
and the power steering fluid container can be lifted out of its locked position by sliding it out of place and pushed to the side
this will give you a little more room, just suck up the pain and go after it... that worked for me [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 8, 2002
i'm not worried about pain, i just dont wanna break anything, and i wasnt sure how to go about getting behind the headlamp withou tearing my whole front end off, and i emailed the people i got the headlamps from and they said i need a h1 for the highbeam which is a foglamp bulb? got me?
Old Jul 8, 2002
ironcow's Avatar
yeah i got you...you shouldnt break anything
i didnt at lease, and i dont know that much about installing things...
as long as you can get the front left one in the easier one...the other one should be fine
Old Jul 8, 2002
speedracersong's Avatar
u can change the bulbs w/o removing the bumper or the headlamp. its just a pain in the a s s
Old Jul 8, 2002
CivicHX01's Avatar
replacing the low beams is no problem... the high beams you have to take off the bumper and take off the projectors..
bowie
Jan 21, 2018 09:29 PM
cferry7
Oct 18, 2015 06:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
