Clicking Sound Coming from Front Right Wheel Well
Old May 29, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Whenever I take a right hand turn at low speeds I get a clicking sound throughout the turn originating from my front right wheel well. The car has 2500 miles on it. I remember reading a few threads about noise coming from there but I could not locate them again on the search. Anyone else have this problem and if so, is there a solution...I'd rather not have to bring it to the dealer and find out its nothing...
Thanks
Old May 29, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
This sounds like you should be bringing that car back to HONDA and having them check out your CV shaft.
Old May 29, 2002
OCTANECOUPE's Avatar
OCTANECOUPE is an unknown quantity at this point
i had same problem,(after 2inch drop on car)for about 2 weeks, it gradually went away. so if you recently lowered your car id give the springs time to settle. if you havent lowered then id take it to the dealer
Old May 29, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
Here's what most of the threads had discussed almost a year ago about this noise... (paraphrasing)
The noise is from the brake pads not seated tightly in the caliper. I personally started noticing this around the 3k mile mark, and has yet to go away. I only notice the noise when car jars forward or backward enuf to have to pad reajust it's self.
Honda has acknoldged the issue and said the fix was to insert folded up business cards to fill the gap. Yes, business cards!
I went to my dealer to have it fixed, they come back and told me that it is a commonly reported issue with most Honda vehicles and doesn't require any service on their part, because it's not something that affects the proformance or operating conditions of the car.
Try getting some new pads (AEM/Nissan) or do the business card thing. I remember some members did that and it fixed the problem.
Old May 29, 2002
bo0sT's Avatar
bo0sT is an unknown quantity at this point
sweet! i was worried it was my cv joint.. i got the same problem in the same place! thanks dude.
Old May 29, 2002
speedracersong's Avatar
i got another click problem.
didnt feel like starting a new thread.
when i first start my car in the morning. at the same stop sign i hear a click from the front of the car when i apply the brake like at 5-10mph.
Old May 29, 2002
7thgencivicdriver's Avatar
7thgencivicdriver is an unknown quantity at this point
Same noise here. I've taken it to two different Honda dealers to have it checked out, both told me it was my springs (Gold Lines 1.5" drop). The last honda dealer also told me that my exhaust piping was also rubbing pretty bad. I have a way of fixing the exhaust problem, don't know about the springs. I'm going to see what the guy who put them in for me says.
Just my 2 cents.[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old May 30, 2002
2ndScratch's Avatar
2ndScratch is an unknown quantity at this point
mine did the same thing but it only did it when i was giving it gas around a turn. ended up being a loose shift fork and honda just replaced the whole tranny @ 2000 miles becasue they didn't know what caused it. prolly had something to do with all my 2nd scratches.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old May 30, 2002
BlueMeanie's Avatar
BlueMeanie is an unknown quantity at this point
lets not get too carried away now...honda has a bulletin for leaky CV boots....i was one of them, my front right rubber CV boot came untighend and was slinging axle grease everywhere...take it to honda and tell them to look at the CV joint and CV boot, dont tell them its a clicking noise, b/c theyll give you that "we cant do anything because of the aftermarket suspension products" bullsh*t so trus me, it wont cost n e thing, so its worth a try
Old Jun 1, 2002
TOOLOWCIVIC's Avatar
Hey my car does the same thing except in the driver side. Could it be my ground control or is it something else? Will it ever go away?
Old Jun 3, 2002
frekyjason2002's Avatar
frekyjason2002 is an unknown quantity at this point
if you have GC coilovers, raise car, oil the upper ring(top and bottom), the washers(all of them), and the top of the adjustable ring. also go to the place where they were installed and tell them to put the lock lugs in place(allen wrench screws) to hold the sleeve in place and keep it from turning when you make a turn. it worked for me. no more clicking or sqeaking.
Old Jun 4, 2002
I don't think that is the problem for me becuase my steering wheel shakes when I hear that loud noise. It sounds like my rim is going to come off. My friend told me that I need to replace all the studs becuase they are going bad.
Old Jun 5, 2002
VROOM's Avatar
VROOM is an unknown quantity at this point
me too. also when it rains i hear it.
chuffsy
May 15, 2015 12:50 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
May 1, 2015 09:37 AM
eX2ooo
Oct 5, 2001 12:19 AM
